cut off object bottom in cura 2.1
lance-greene
Posted · cut off object bottom in cura 2.1
Hi Lance,
When you have your model in Cura, just click on it to make appear the XYZ axes (Red, Green, Blue) and then keep clicking on Z axis and slide it down.
That's not as much precise as it could be before but in the down right angle you can see the "new" size of your object.
Tell me if you need more info ! (:
        • 6 replies
