Ultimaker 2 upgraded to plus - hard to load filament
Posted
· Ultimaker 2 upgraded to plus - hard to load filament
It's getting caught in the transition between the bowden tube and the TFM (the milky white piece in the middle of the head). Often you can get the filament to get past this area by grabbing the bowden tube at the head and wiggling it back and forth.
If that doesn't help you can try straightening the top of the filament and cut it at an angle to form a sharp point.
Also, if you need to move the filament quickly, just push the lever on the feeder upwards and pull/push the filament manually.
How to Enter
Design an Ornament
Entering a new design
Entering an existing design
Winning designs should:
Be original Creations
Share the creative journey! Include documentation of your design process, giving us a peek behind the scenes. For example, show a screenshot of the model in your design program. Use the Tag Holidays2023.
Make sure your submission aligns with our guidelines and Thingiverse's Terms of Service.
Good luck 🎉
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
IRobertI 517
