i have both installed and use both depending on the project. when i want to throw something at the printer without much thinking or if there is lots of details in the layer view, i use 15.04, but most of the time, I have settled for 2.1.2.
If so, people could simply install both, and use the version that works best for a particular task. Or they could just keep the old one as a fall-back.
Yep. You'd almost think we designed software so it's easy for us to use and compare
OK thanks for the comments. I will load up the new version and start wrapping my head around it.
I will run them both for a while just in case something gives.
Looks like fun!
Thanks!
- 3 weeks later...
Old one or Simplify3D all day, Cura 2.1.2 is hopeless.
Does 15.04.6 and 2.1.2 use the same version of Marlin, or do we need to keep swapping?
They use the same version. No worries We will stop to update the old Cura at some point in time (This also means that at some point you will need to use cura 2.x if you want new firmware)
- 3 weeks later...
Well I am getting on pretty OK with the new version now. Perhaps its the never-ending list of settings that are available now and making sure the ones I need are on the main view.
Working well I have to say
Simplify3D or Formide. Cura-BCN3D-0.1.5-beta is also hopeless!
Simplify3D or Formide. I'm struggling with Cura and dual extrusion machines and those two don't give me issues. Cura-BCN3D-0.1.5-beta is also hopeless!
Formide is actually a fork of CuraEngine. Dual extrusion will also have received tweaks in 2.2
Edited by Guest-
1
I use 2.1.2 for the new supports capability and I like the concentric top/bottom fill patterns. I only do PLA and ABS with it though.
For everything else (other materials, no supports needed, etc.) I use 15.04.6. It's more complete, faster, and just works. But supports are terrible.
Once 2.x grows more, I can see transitioning to it fully, but certainly not yet. It's just a baby, give it time to grow strong before you put it in the work force.
Just my $0.02.
Will Cura 2.1 be able to load gcode files eventually?
14.09 is the best version I've used (and still do).
Later versions (definitely 15.02 and later) all cause prints to take much longer than necessary.
I think it's related to the way retraction is performed but I've not quite worked out exactly what changed.
It's a shame really because I would like to use the new features in 2.x but I can't accept an increase in print time of 25 to 100 %.
Yes. But it's not planned for 2.2
Does it actually increase or is it just the estimation that is different? I very much doubt that the actual print time increases by 100% by something that happened between 14.09 and 15.02. Especially because after two years you're the first person to report the issue.
Edited by GuestI also have both installed and it really depends what you need the slicer for.
Why is the cura 15.04.6 the old UI again? I must have missed this point... does not make any sense.
J
Dim3nsioneer 557
15.04.x are the legacy versions. It's still the old interface not again...
Sorry for the delay in replying I have been on holiday
I have reported this before.
I have read posts of at least one other person who has noticed the same thing.
The time increase is REAL not estimated.
It depends on the item being printed but yes the print time increases by 100 % for some objects and a significant amount for all objects.
Edited by GuestWell @prb4 if you want someone to fix this, please post an STL and the 2 gcode files created so someone can analyze what is different and maybe make an improvement to the latest cura. Really the entire gcode files need be posted as that will include any scaling you did, multiple objects, and will include all settings. You can't post them here so post them in dropbox or some other web site that you have control over (preferably not something that will only host the files for a month).
nallath 1,118
As the only dev to do work on both versions I can name quite a few differences. The most notable one are pretty much invisible to users (The old architecture was a pretty big mess)
For normal use it pretty much comes down to;
2.1 -> More features, slightly slower slicing (but better handling of edge cases), slower layer view, a ton of extra settings, easier to expand. Will continue to get updates / development. Faster rendering.
15.04 -> Less features, somewhat faster slicing, faster layer view, can load g-code files. Won't get updates anymore in the near future.
geert_2 557
Hi nallath,
Can old and new (>2.1) Cura versions be installed parallel on the same system, without messing each other's settings up? Do they use separate directories and files?
Geert
