Get a umo+ and the um2+ upgrade kit. That would be 1500. Then you can get a I2K. The I2K it's a spacer that once installed between the tft/ptfe coupler will allow you to print 280-290C (afaik).
To install the um2+ kit upgrade:
https://ultimaker.com/en/community/21167-assembly-manual-um2-upgrade-kit-on-ultimaker-original-plus
If you like the idea make and have more questions you know, just ask
Edit: Anyway remember that you will get a cheaper machine, but you will need to invest personal time to adjust everything to make it work almost as good as a um2. So you save some cash, but you will need to work for a week or so (assuming you have experience modding printers) so everything it's close to what a full assembled machine with a better frame can offer.
nallath 1,125
I guess you would need to buy a second hand machine if you want one below 1000$.
Officially the highest temp you can get is 260. It's possible to go higher, but you would need to make modifications.
