I like it, very cool idea. The one thing that would worry me is if repeated bending of the plate would lead to it bowing up in the center and causing problems.
It's symmetrical, right? Flip it over and bend away?
You are bending acrylic. It WILL eventually break. It's a trade off between practicality and cost. A material that will bend without fatigue will be more easily warped, and we don't want that.
But the only engraving the thin plate needs is the bolt's seats. The rest can be seen through from the thick base.
One thin plate cost me 30 Argentinian pesos (4 euros). It's the cost of just one failed print job.
Last minute update: Objects do bend a bit. This piece was printed in the center of the plate.
I guess that even if the borders are clamped, the compression in the center of the upper face will bend the thin plate like an "M". Even if it is stretched, the tension needed to avoid having just a couple of degrees bent should be way too high.
It was a nice idea, oh well... and I wondered why nobody had tried that one before...
I have some other ideas, like using an unbent half pipe so that it has lots of tension built in. Or making the build platform with tiles, so that when you pull a string they all come apart easily...
So many ideas, so little time... :mrgreen:
That's normal warping. Unfortunately something that you have to live with if you don't have a heated bed. Sure, there are tricks to help minimize the effect like adding "mouse ears" to the corners, putting a brim on the part, print less solid, play with temperature, change when the fan kicks in etc etc but in my experience it never fully goes away.
IRobertI 513
