Hey @SandervG, @catohagen!
Yes, they fit.
It is right they do not fit perfectly since they make not "head" contact with the heater block, but this is almost fully compensated by the longer threading!
It will extend from block less , so you need to align the bed a little higher up.
Make sure, like with ordinary nozzles, that there is a full and firm contact between the nozzle and the brass-rod/screw, else you will have a leak!
Will be interesting to see your results!
SandervG 1,499
You should be best off asking @Swordriff
