Thanks for the tip and it definitely made it better, but the is still a slight deformation which makes the the nut and bolt not screw together still?Hi @KnarlyNick,
Welcome to the forums! Usually when your circles are not round this means that one, or both of your short belts are not tight enough. You can tighten them by loosening the 4 screws that hold the X or Y motor in its place, push it down as far as you can, and tighten them again.
If you do this for both X and Y motor, you should see much rounder cylinders
Cylinders print more like a square?
Could it be that there is just friction in between the parts?
PLA on PLA has quite a high friction. Sanding it down and / or applying some WD40 or sewing machine oil may make all the difference in the world.
Alternatively, download and print a model like this one and make sure your X and Y axis are calibrated correctly, like a perfect +
Good luck!
SandervG 1,522
Hi @KnarlyNick,
