Posted
(edited)
· UM2+ (fixed spacer) check with Air
Did some basic test with my air compressor and if it's too loose you can actually fell the air on the fingers (if you partially block the exit). So I don't think that this would work with an already assembled hotend unless you can actually put talc powder to be able to detect small parts of air moving there. At 50psi it was quite easy to spot the air, but much harder to stop the air from the other side.
Anyhow, I think the problem of hotends leaving gaps, it's that since the structure it's basically only supported by the alublock that goes in front of the fan, then it's quite easy to tilt the aluminium parts by doing too much pressure. So to actually be able to do the 'correct' pressure, you need to add the x4 long screws that pull the hanging parts of the top/bottom of the aluminium parts. I suppose a good trick could be to make pilars or some structure to actually be able to see when the excess of pressure it's actually bending the top/bottom.
We don't often release an alpha version of Ultimaker Cura... So what's different this time? This Alpha contains such a huge slicing engine overhaul that we really need your help!
We wish to celebrate and honor the innovators that push forward the field, technology and world. We opted to not present it as a competition or ranked list. Every innovator has earned his spot on that list in their own way. We also look at the 3D printing industry as a whole and not limit the list to those only using Ultimaker.
neotko 1,415
Edited by GuestLink to post
