Yes, in Cura I added a new machine, upgrade firmware and checked/reset all settings .
Go to Control -> Motion and change the z steps to 400. A factory reset removes the adjustments you could do or had on the machine and re-reads the info of the firmware.
Control setting:
Accel: 4000
Vxy-jerk: 20
Vz-jerk: +000.40
Ve-jerk: 5
Vmax x: 500
Vmax y: 500
Vmax z: 5
Vmax e: 25
Amax x: 9000
Amax y: 9000
Amax z: 100
Amax e: 10000
A-retract: 3000
Xsteps/mm: +078.74
Ysteps/mm: +078.74
Zsteps/mm: +0400.1
Esteps/mm: +0836.0
Photo :
(What is a factory reset?) I did : calibration, bed levelling, fine-tuning.
Maybe you can see some mistakes or errors in my settings (ulticontroller)
Lol sorry. 200 steps on Z change that 400.1 to 200
Sorry for the mistake I'm at 5 thinks at the same time.
Edited by Guest-
1
Thank you!! It is a square! (not a rectangle anymore)
Is it possible to set this settings? Now I am spinning 200 every time.
You have a 'save settings' on Control -> Store memory
Also there you have an option called 'restore failsafe' that I think it does what @IRobertI suggested. I never used it so I'm not sure if does that
1
Thank you !!! You made my day!!
1
answer :
"set settings" :
-Control -> Motion -> Zsteps/mm: +0200.0
"save settings":
-Control -> Store memory
Thank you Neotko!!!!
IRobertI 473
Have you updated your firmware to match your upgrade and performed a factory reset?
