Did I get auto-upgraded?
DaHai8
Posted · Did I get auto-upgraded?
Strange behavior from Cura this evening:
I started it up by double-clicking an .stl file, like I usually do, Comura Articulatum from Thingiverse, and Cura launched like it was a fresh install on my laptop!
It gave me some quick hint windows, a little welcome to Cura and made me choose a printer. Thankfully, my Aurora A3 was still in the list - whew! But it came up in 'Simple" setup mode (I never use Simple mode). So I switched to 'Advanced' and all the settings I had made visible before were gone :(
Then I noticed I had 2 Aurora A3 Printers in my 'Printers:' selection. The second was set for ABS (I never print in ABS). So I removed that one.
Went in and re-enabled all the 'Setting Visibility' items and AFAICT none of my presets were lost: speed, infill, raft parms, etc. and even my custom print bed .stl still shows.
Oddly, the version still says 2.1.2, so if I was auto-upgraded, the version number wasn't changed.
No harm, no foul. Just odd and a little worrisome for a moment.
Does Cura auto-upgrade now? Or did it just lose its marbles this time?
    Ok, I think I got the answer to my primary question: I did not get auto-updated/upgraded. I just now restarted Cura to make sure all the settings where still there/correct/etc. (which they were) and got a little window says "A new version of Cura is available!".
    So clearly I was not upgraded....so what happened that caused it to forget everything and act like a fresh install?
    puzzling....
    There is no auto-upgrade in Cura.
    The only thing I can think of that causes this is some sort of data corruption on your local system. At that point it can't find the machines / profiles, so it asks you to add a new machine.
        • 9 replies
