For problem 2, since you already tested that, try to do that again, but also try to do the x/y calibration before fixing the pulleys. Sometimes it's a mix of both. I got tired on my ultimaker of that and the final fix was to move to a better GT2 pulley/belt, since the Ultimaker O+ pulleys (at least the ones I got on 2 machines) are pure caca with a lot of eccentricity.
Final note, sorry many post but fast writing!
I highly recommend you that you use the https://bultimaker.bulles.eu/experimental/
This unlocks the PID for the BED (removing the bangbang). This improves the layer-to-layer quality by A LOT.
First, thank you for your replies. I will look into new firmware and pulleys.
Regarding the temperature. I havent tought about it before and while looking at my printer just now I do notice that it moves a fair bit between 209-211. Swinging between. Can this be the issue?
It might. I had some quality issues on the umo+ until fixed the pid. On 2 machines was always spot on but the third did need PID adjustment. Changing the temp changes (on some pla brands) the color/gloss/etc.
Do you know of a guide how to do the PID adjustment?
https://ultimaker.com/en/community/4634-pid-autotune#reply-29067
Basically you connect to the printer and send the gcode so the autotune starts to work. It will do heat cicles and at the end will report a PID values to enter by gcode and then you store the new values on the eprom by M500.
Download the printrun/pronterface software (free) http://www.pronterface.com
For the ugly print issue. Have you tried printing a circle to see if it's a "perfect" circle or not? I'm thinking it could be a bit of backlash at play here.
1
neotko 1,418
Problem 3. Probably some screw on the fan need's some 'screwing'.
Problem 2. The belts aint perfectly in alignment. https://ultimaker.com/en/community/20897-questions-after-umo-upgrade-to-gt2-belts-and-pulleys#reply-145972
Problem 1. Check that the heat of the hotend it's totally stable. If while prints it keeps constantly going up/down then you should run a PID adjustment to make it better.
Something like this (using printrun/pronterface free software to connect by USB to the printer) https://ultimaker.com/en/community/18625-solved-um2-pid-autotune-failed This it's for um2, but it's the same process for any ultimaker (and many many other printers).
