Solved Cura 2 on debian sid
fma
Posted (edited) · Solved Cura 2 on debian sid
Hi!
I'm trying to run Cura 2 (2.1.3) on my debian sid. I had to compile Python3.4, as the distro now uses Python3.5.
But then, I only see the splashscreen, with the following messages:
libGL error: unable to load driver: r600_dri.solibGL error: driver pointer missinglibGL error: failed to load driver: r600libGL error: unable to load driver: r600_dri.solibGL error: driver pointer missinglibGL error: failed to load driver: r600libGL error: unable to load driver: swrast_dri.solibGL error: failed to load driver: swrast2016-08-24 13:10:09,619 - INFO - Loaded plugin ConsoleLogger2016-08-24 13:10:09,734 - INFO - Loaded plugin CuraEngineBackend2016-08-24 13:10:09,753 - INFO - Loaded plugin FileLogger2016-08-24 13:10:10,001 - INFO - Loaded plugin 3MFWriter2016-08-24 13:10:10,005 - INFO - Loaded plugin STLReader2016-08-24 13:10:10,009 - INFO - Loaded plugin STLWriter2016-08-24 13:10:10,012 - INFO - Loaded plugin OBJWriter2016-08-24 13:10:10,017 - INFO - Loaded plugin OBJReader2016-08-24 13:10:10,248 - INFO - Checking for new version of cura2016-08-24 13:10:10,249 - INFO - Loaded plugin UpdateChecker2016-08-24 13:10:10,389 - INFO - Loaded plugin ScaleTool2016-08-24 13:10:10,397 - INFO - Loaded plugin TranslateTool2016-08-24 13:10:10,444 - INFO - Loaded plugin RotateTool2016-08-24 13:10:10,449 - INFO - Loaded plugin CameraTool2016-08-24 13:10:10,469 - INFO - Loaded plugin SelectionTool2016-08-24 13:10:10,488 - INFO - Loaded plugin MirrorTool2016-08-24 13:10:10,495 - INFO - Loaded plugin LocalFileOutputDevice2016-08-24 13:10:10,498 - INFO - Loaded plugin SimpleView2016-08-24 13:10:10,502 - INFO - Loaded plugin WireframeView2016-08-24 13:10:10,502 - WARNING - Plugin ConsoleLogger was already loaded2016-08-24 13:10:10,517 - INFO - Loaded plugin 3MFReader2016-08-24 13:10:10,521 - INFO - Loaded plugin AutoSave2016-08-24 13:10:10,543 - INFO - Loaded plugin RemovableDriveOutputDevice2016-08-24 13:10:10,722 - INFO - Loaded plugin USBPrinting2016-08-24 13:10:10,728 - INFO - Loaded plugin SliceInfoPlugin2016-08-24 13:10:10,750 - INFO - Loaded plugin PostProcessingPlugin2016-08-24 13:10:10,758 - INFO - Loaded plugin ImageReader2016-08-24 13:10:10,763 - INFO - Loaded plugin CuraProfileReader2016-08-24 13:10:10,775 - INFO - Loaded plugin GCodeProfileReader2016-08-24 13:10:10,799 - INFO - Loaded plugin PerObjectSettingsTool2016-08-24 13:10:10,800 - WARNING - Plugin CuraEngineBackend was already loaded2016-08-24 13:10:10,805 - INFO - Loaded plugin LegacyProfileReader2016-08-24 13:10:10,815 - ERROR - Exception starting plugin Doodle3D: NotImplementedError('Start should be implemented by subclasses',)2016-08-24 13:10:10,815 - INFO - Loaded plugin Doodle3D2016-08-24 13:10:10,820 - INFO - Loaded plugin SolidView2016-08-24 13:10:10,826 - INFO - Loaded plugin XRayView2016-08-24 13:10:10,832 - INFO - Loaded plugin ChangeLogPlugin2016-08-24 13:10:10,837 - INFO - Loaded plugin GCodeWriter2016-08-24 13:10:10,846 - INFO - Loaded plugin LayerView2016-08-24 13:10:10,851 - INFO - Loaded plugin CuraProfileWriter2016-08-24 13:10:10,851 - INFO - Command line arguments: {'debug-mode': False, 'disable-textures': False, 'file': [], 'external-backend': False}2016-08-24 13:10:11,082 - INFO - Started engine process: /opt/cura/bin/CuraEngine2016-08-24 13:10:11,099 - DEBUG - Setting active view to SolidViewUnrecognized OpenGL versionUnrecognized OpenGL version
and nothing more happens.
I'm using a Caicos [Radeon HD 6450/7450/8450 / R5 230 OEM] graphic card, with the free Xorg drivers.
Here is the Xorg logs:
X.Org X Server 1.18.4Release Date: 2016-07-19[    32.627] X Protocol Version 11, Revision 0[    32.627] Build Operating System: Linux 3.16.0-4-amd64 x86_64 Debian[    32.627] Current Operating System: Linux ceatux 4.6.0-1-amd64 #1 SMP Debian 4.6.4-1 (2016-07-1 x86_64[    32.627] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.6.0-1-amd64 root=UUID=ff8ef56f-52b0-489e-87bc-bff3a4766b4d ro quiet[    32.627] Build Date: 20 July 2016  05:14:41AM[    32.627] xorg-server 2:1.18.4-1 (http://www.debian.org/support) [    32.627] Current version of pixman: 0.33.6[    32.627] Before reporting problems, check http://wiki.x.orgto make sure that you have the latest version.[    32.627] Markers: (--) probed, (**) from config file, (==) default setting,(++) from command line, (!!) notice, (II) informational,(WW) warning, (EE) error, (NI) not implemented, (??) unknown.[    32.627] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Aug 19 08:19:20 2016[    32.695] (==) Using system config directory "/usr/share/X11/xorg.conf.d"[    32.765] (==) No Layout section.  Using the first Screen section.[    32.765] (==) No screen section available. Using defaults.[    32.765] (**) |-->Screen "Default Screen Section" (0)[    32.765] (**) |   |-->Monitor ""[    32.777] (==) No monitor specified for screen "Default Screen Section".Using a default monitor configuration.[    32.777] (==) Automatically adding devices[    32.777] (==) Automatically enabling devices[    32.777] (==) Automatically adding GPU devices[    32.777] (==) Max clients allowed: 256, resource mask: 0x1fffff[    32.864] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.[    32.864] Entry deleted from font path.[    32.938] (==) FontPath set to:/usr/share/fonts/X11/misc,/usr/share/fonts/X11/100dpi/:unscaled,/usr/share/fonts/X11/75dpi/:unscaled,/usr/share/fonts/X11/Type1,/usr/share/fonts/X11/100dpi,/usr/share/fonts/X11/75dpi,built-ins[    32.938] (==) ModulePath set to "/usr/lib/xorg/modules"[    32.938] (II) The server relies on udev to provide the list of input devices.If no devices become available, reconfigure udev or disable AutoAddDevices.[    32.949] (II) Loader magic: 0x557ad3beddc0[    32.950] (II) Module ABI versions:[    32.950] X.Org ANSI C Emulation: 0.4[    32.950] X.Org Video Driver: 20.0[    32.950] X.Org XInput driver : 22.1[    32.950] X.Org Server Extension : 9.0[    32.951] (++) using VT number 7[    32.951] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration[    32.951] (II) xfree86: Adding drm device (/dev/dri/card0)[    32.952] (--) PCI:*(0:1:0:0) 1002:6779:1028:2120 rev 0, Mem @ 0xd0000000/268435456, 0xe1520000/131072, I/O @ 0x00004000/256, BIOS @ 0x????????/131072[    32.953] (II) LoadModule: "glx"[    33.009] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so[    33.856] (II) Module glx: vendor="X.Org Foundation"[    33.856] compiled for 1.18.4, module version = 1.0.0[    33.856] ABI class: X.Org Server Extension, version 9.0[    33.856] (==) AIGLX enabled[    33.856] (==) Matched ati as autoconfigured driver 0[    33.856] (==) Matched ati as autoconfigured driver 1[    33.856] (==) Matched modesetting as autoconfigured driver 2[    33.856] (==) Matched fbdev as autoconfigured driver 3[    33.856] (==) Matched vesa as autoconfigured driver 4[    33.856] (==) Assigned the driver to the xf86ConfigLayout[    33.856] (II) LoadModule: "ati"[    33.868] (WW) Warning, couldn't open module ati[    33.868] (II) UnloadModule: "ati"[    33.868] (II) Unloading ati[    33.868] (EE) Failed to load module "ati" (module does not exist, 0)[    33.868] (II) LoadModule: "modesetting"[    33.868] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so[    33.899] (II) Module modesetting: vendor="X.Org Foundation"[    33.899] compiled for 1.18.4, module version = 1.18.4[    33.899] Module class: X.Org Video Driver[    33.899] ABI class: X.Org Video Driver, version 20.0[    33.899] (II) LoadModule: "fbdev"[    33.899] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so[    33.916] (II) Module fbdev: vendor="X.Org Foundation"[    33.916] compiled for 1.18.0, module version = 0.4.4[    33.916] Module class: X.Org Video Driver[    33.916] ABI class: X.Org Video Driver, version 20.0[    33.916] (II) LoadModule: "vesa"[    33.916] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so[    33.926] (II) Module vesa: vendor="X.Org Foundation"[    33.926] compiled for 1.18.0, module version = 2.3.4[    33.926] Module class: X.Org Video Driver[    33.926] ABI class: X.Org Video Driver, version 20.0[    33.926] (II) modesetting: Driver for Modesetting Kernel Drivers: kms[    33.926] (II) FBDEV: driver for framebuffer: fbdev[    33.926] (II) VESA: driver for VESA chipsets: vesa[    33.933] (II) modeset(0): using drv /dev/dri/card0[    33.933] (WW) Falling back to old probe method for fbdev[    33.933] (II) Loading sub module "fbdevhw"[    33.933] (II) LoadModule: "fbdevhw"[    33.933] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so[    33.947] (II) Module fbdevhw: vendor="X.Org Foundation"[    33.947] compiled for 1.18.4, module version = 0.0.2[    33.947] ABI class: X.Org Video Driver, version 20.0[    33.947] (WW) Falling back to old probe method for vesa[    33.947] (II) modeset(0): Creating default Display subsection in Screen section"Default Screen Section" for depth/fbbpp 24/32[    33.947] (==) modeset(0): Depth 24, (==) framebuffer bpp 32[    33.947] (==) modeset(0): RGB weight 888[    33.947] (==) modeset(0): Default visual is TrueColor[    33.947] (II) Loading sub module "glamoregl"[    33.947] (II) LoadModule: "glamoregl"[    33.947] (II) Loading /usr/lib/xorg/modules/libglamoregl.so[    34.087] (II) Module glamoregl: vendor="X.Org Foundation"[    34.087] compiled for 1.18.4, module version = 1.0.0[    34.087] ABI class: X.Org ANSI C Emulation, version 0.4[    34.087] (II) glamor: OpenGL accelerated X.org driver based.[    36.769] (II) glamor: EGL version 1.4 (DRI2):[    36.949] (II) modeset(0): glamor initialized[    36.967] (II) modeset(0): Output DP-1 has no monitor section[    37.004] (II) modeset(0): Output DVI-I-1 has no monitor section[    37.023] (II) modeset(0): EDID for output DP-1[    37.060] (II) modeset(0): EDID for output DVI-I-1[    37.060] (II) modeset(0): Manufacturer: DEL  Model: a07a  Serial#: 843135308[    37.060] (II) modeset(0): Year: 2012  Week: 7[    37.060] (II) modeset(0): EDID Version: 1.3[    37.060] (II) modeset(0): Digital Display Input[    37.060] (II) modeset(0): Max Image Size [cm]: horiz.: 52  vert.: 32[    37.060] (II) modeset(0): Gamma: 2.20[    37.060] (II) modeset(0): DPMS capabilities: StandBy Suspend Off[    37.060] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4 [    37.060] (II) modeset(0): First detailed timing is preferred mode[    37.060] (II) modeset(0): redX: 0.640 redY: 0.330   greenX: 0.300 greenY: 0.600[    37.060] (II) modeset(0): blueX: 0.150 blueY: 0.060   whiteX: 0.313 whiteY: 0.329[    37.060] (II) modeset(0): Supported established timings:[    37.060] (II) modeset(0): 720x400@70Hz[    37.060] (II) modeset(0): 640x480@60Hz[    37.060] (II) modeset(0): 800x600@60Hz[    37.060] (II) modeset(0): 1024x768@60Hz[    37.060] (II) modeset(0): Manufacturer's mask: 0[    37.060] (II) modeset(0): Supported standard timings:[    37.060] (II) modeset(0): #0: hsize: 1280  vsize 960  refresh: 60  vid: 16513[    37.060] (II) modeset(0): #1: hsize: 1280  vsize 1024  refresh: 60  vid: 32897[    37.060] (II) modeset(0): #2: hsize: 1600  vsize 1200  refresh: 60  vid: 16553[    37.060] (II) modeset(0): #3: hsize: 1680  vsize 1050  refresh: 60  vid: 179[    37.060] (II) modeset(0): #4: hsize: 1920  vsize 1080  refresh: 60  vid: 49361[    37.060] (II) modeset(0): Supported detailed timing:[    37.060] (II) modeset(0): clock: 154.0 MHz   Image Size:  518 x 324 mm[    37.060] (II) modeset(0): h_active: 1920  h_sync: 1968  h_sync_end 2000 h_blank_end 2080 h_border: 0[    37.060] (II) modeset(0): v_active: 1200  v_sync: 1203  v_sync_end 1209 v_blanking: 1235 v_border: 0[    37.060] (II) modeset(0): Serial No: Y1H5T22G2A9L[    37.060] (II) modeset(0): Monitor name: DELL U2412M[    37.060] (II) modeset(0): Ranges: V min: 50 V max: 61 Hz, H min: 30 H max: 83 kHz, PixClock max 175 MHz[    37.060] (II) modeset(0): EDID (in hex):[    37.060] (II) modeset(0): 00ffffffffffff0010ac7aa04c394132[    37.060] (II) modeset(0): 0716010380342078eaee95a3544c9926[    37.060] (II) modeset(0): 0f5054a1080081408180a940b300d1c0[    37.060] (II) modeset(0): 010101010101283c80a070b023403020[    37.060] (II) modeset(0): 360006442100001a000000ff00593148[    37.060] (II) modeset(0): 35543232473241394c0a000000fc0044[    37.060] (II) modeset(0): 454c4c2055323431324d0a20000000fd[    37.060] (II) modeset(0): 00323d1e5311000a2020202020200068[    37.060] (II) modeset(0): Not using default mode "1600x1200" (bad mode clock/interlace/doublescan)[    37.060] (II) modeset(0): Printing probed modes for output DVI-I-1[    37.060] (II) modeset(0): Modeline "1920x1200"x60.0  154.00  1920 1968 2000 2080  1200 1203 1209 1235 +hsync -vsync (74.0 kHz eP)[    37.060] (II) modeset(0): Modeline "1920x1080"x60.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 -hsync -vsync (67.5 kHz e)[    37.060] (II) modeset(0): Modeline "1920x1080"x59.9  138.50  1920 1968 2000 2080  1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)[    37.060] (II) modeset(0): Modeline "1600x1200"x65.0  175.50  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (81.2 kHz d)[    37.060] (II) modeset(0): Modeline "1600x1200"x60.0  162.00  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)[    37.060] (II) modeset(0): Modeline "1680x1050"x69.9  174.00  1680 1800 1976 2272  1050 1053 1059 1096 -hsync +vsync (76.6 kHz d)[    37.060] (II) modeset(0): Modeline "1680x1050"x60.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)[    37.060] (II) modeset(0): Modeline "1680x1050"x59.9  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)[    37.060] (II) modeset(0): Modeline "1600x1024"x60.2  103.12  1600 1600 1656 1664  1024 1024 1029 1030 +hsync +vsync (62.0 kHz d)[    37.060] (II) modeset(0): Modeline "1400x1050"x70.0  145.06  1400 1496 1648 1896  1050 1051 1054 1093 -hsync +vsync (76.5 kHz d)[    37.060] (II) modeset(0): Modeline "1400x1050"x60.0  122.00  1400 1488 1640 1880  1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)[    37.060] (II) modeset(0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)[    37.061] (II) modeset(0): Modeline "1440x900"x59.9  106.50  1440 1520 1672 1904  900 903 909 934 -hsync +vsync (55.9 kHz d)[    37.061] (II) modeset(0): Modeline "1280x960"x60.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)[    37.061] (II) modeset(0): Modeline "1360x768"x59.8   84.75  1360 1432 1568 1776  768 771 781 798 -hsync +vsync (47.7 kHz d)[    37.061] (II) modeset(0): Modeline "1360x768"x60.0   72.00  1360 1408 1440 1520  768 771 781 790 +hsync -vsync (47.4 kHz d)[    37.061] (II) modeset(0): Modeline "1152x864"x70.0   96.77  1152 1224 1344 1536  864 865 868 900 -hsync +vsync (63.0 kHz d)[    37.061] (II) modeset(0): Modeline "1152x864"x60.0   81.62  1152 1216 1336 1520  864 865 868 895 -hsync +vsync (53.7 kHz d)[    37.061] (II) modeset(0): Modeline "1024x768"x60.0  133.47  1024 1100 1212 1400  768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)[    37.061] (II) modeset(0): Modeline "1024x768"x70.1   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz d)[    37.061] (II) modeset(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)[    37.061] (II) modeset(0): Modeline "960x720"x60.0  117.00  960 1024 1128 1300  720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)[    37.061] (II) modeset(0): Modeline "928x696"x60.1  109.15  928 976 1088 1264  696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)[    37.061] (II) modeset(0): Modeline "896x672"x60.0  102.40  896 960 1060 1224  672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)[    37.061] (II) modeset(0): Modeline "960x600"x60.0   77.00  960 984 1000 1040  600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)[    37.061] (II) modeset(0): Modeline "960x540"x60.0   69.25  960 984 1000 1040  540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)[    37.061] (II) modeset(0): Modeline "800x600"x70.0   94.50  800 832 928 1080  600 600 602 625 doublescan +hsync +vsync (87.5 kHz d)[    37.061] (II) modeset(0): Modeline "800x600"x65.0   87.75  800 832 928 1080  600 600 602 625 doublescan +hsync +vsync (81.2 kHz d)[    37.061] (II) modeset(0): Modeline "800x600"x60.0   81.00  800 832 928 1080  600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)[    37.061] (II) modeset(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)[    37.061] (II) modeset(0): Modeline "800x600"x56.2   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz d)[    37.061] (II) modeset(0): Modeline "840x525"x69.9   87.00  840 900 988 1136  525 526 529 548 doublescan -hsync +vsync (76.6 kHz d)[    37.061] (II) modeset(0): Modeline "840x525"x60.0   73.12  840 892 980 1120  525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)[    37.061] (II) modeset(0): Modeline "840x525"x59.9   59.50  840 864 880 920  525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)[    37.061] (II) modeset(0): Modeline "800x512"x60.2   51.56  800 800 828 832  512 512 514 515 doublescan +hsync +vsync (62.0 kHz d)[    37.061] (II) modeset(0): Modeline "700x525"x70.1   72.53  700 748 824 948  525 525 527 546 doublescan -hsync +vsync (76.5 kHz d)[    37.061] (II) modeset(0): Modeline "700x525"x60.0   61.00  700 744 820 940  525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)[    37.061] (II) modeset(0): Modeline "640x512"x60.0   54.00  640 664 720 844  512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)[    37.061] (II) modeset(0): Modeline "720x450"x59.9   53.25  720 760 836 952  450 451 454 467 doublescan -hsync +vsync (55.9 kHz d)[    37.061] (II) modeset(0): Modeline "640x480"x60.0   54.00  640 688 744 900  480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)[    37.061] (II) modeset(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)[    37.061] (II) modeset(0): Modeline "720x400"x70.1   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)[    37.061] (II) modeset(0): Modeline "680x384"x59.8   42.38  680 716 784 888  384 385 390 399 doublescan -hsync +vsync (47.7 kHz d)[    37.061] (II) modeset(0): Modeline "680x384"x60.0   36.00  680 704 720 760  384 385 390 395 doublescan +hsync -vsync (47.4 kHz d)[    37.061] (II) modeset(0): Modeline "576x432"x70.0   48.38  576 612 672 768  432 432 434 450 doublescan -hsync +vsync (63.0 kHz d)[    37.061] (II) modeset(0): Modeline "576x432"x60.1   40.81  576 608 668 760  432 432 434 447 doublescan -hsync +vsync (53.7 kHz d)[    37.061] (II) modeset(0): Modeline "512x384"x70.1   37.50  512 524 592 664  384 385 388 403 doublescan -hsync -vsync (56.5 kHz d)[    37.061] (II) modeset(0): Modeline "512x384"x60.0   32.50  512 524 592 672  384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)[    37.061] (II) modeset(0): Modeline "400x300"x60.3   20.00  400 420 484 528  300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)[    37.061] (II) modeset(0): Modeline "400x300"x56.3   18.00  400 412 448 512  300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)[    37.061] (II) modeset(0): Modeline "320x240"x60.1   12.59  320 328 376 400  240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)[    37.061] (II) modeset(0): Output DP-1 disconnected[    37.061] (II) modeset(0): Output DVI-I-1 connected[    37.061] (II) modeset(0): Using exact sizes for initial modes[    37.061] (II) modeset(0): Output DVI-I-1 using initial mode 1920x1200 +0+0[    37.061] (II) modeset(0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.[    37.061] (==) modeset(0): DPI set to (96, 96)[    37.061] (II) Loading sub module "fb"[    37.061] (II) LoadModule: "fb"[    37.061] (II) Loading /usr/lib/xorg/modules/libfb.so[    37.085] (II) Module fb: vendor="X.Org Foundation"[    37.085] compiled for 1.18.4, module version = 1.0.0[    37.085] ABI class: X.Org ANSI C Emulation, version 0.4[    37.085] (II) UnloadModule: "fbdev"[    37.085] (II) Unloading fbdev[    37.085] (II) UnloadSubModule: "fbdevhw"[    37.085] (II) Unloading fbdevhw[    37.085] (II) UnloadModule: "vesa"[    37.085] (II) Unloading vesa[    37.085] (==) Depth 24 pixmap format is 32 bpp[    37.178] (==) modeset(0): Backing store enabled[    37.178] (==) modeset(0): Silken mouse enabled[    37.179] (II) modeset(0): RandR 1.2 enabled, ignore the following RandR disabled message.[    37.180] (==) modeset(0): DPMS enabled[    37.180] (II) modeset(0): [DRI2] Setup complete[    37.180] (II) modeset(0): [DRI2]   DRI driver: r600[    37.180] (II) modeset(0): [DRI2]   VDPAU driver: r600[    37.180] (--) RandR disabled[    37.185] (II) SELinux: Disabled on system[    37.187] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer[    37.187] (II) AIGLX: enabled GLX_ARB_create_context[    37.187] (II) AIGLX: enabled GLX_ARB_create_context_profile[    37.187] (II) AIGLX: enabled GLX_EXT_create_context_es{,2}_profile[    37.187] (II) AIGLX: enabled GLX_INTEL_swap_event[    37.187] (II) AIGLX: enabled GLX_SGI_swap_control and GLX_MESA_swap_control[    37.187] (II) AIGLX: enabled GLX_EXT_framebuffer_sRGB[    37.187] (II) AIGLX: enabled GLX_ARB_fbconfig_float[    37.187] (II) AIGLX: enabled GLX_EXT_fbconfig_packed_float[    37.187] (II) AIGLX: GLX_EXT_texture_from_pixmap backed by buffer objects[    37.187] (II) AIGLX: enabled GLX_ARB_create_context_robustness[    37.188] (II) AIGLX: Loaded and initialized r600[    37.188] (II) GLX: Initialized DRI2 GL provider for screen 0[    37.189] (II) modeset(0): Setting screen physical size to 508 x 317[    37.648] (II) config/udev: Adding input device Power Button (/dev/input/event4)[    37.648] (**) Power Button: Applying InputClass "evdev keyboard catchall"[    37.648] (**) Power Button: Applying InputClass "libinput keyboard catchall"[    37.648] (II) LoadModule: "libinput"[    37.648] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so[    37.784] (II) Module libinput: vendor="X.Org Foundation"[    37.784] compiled for 1.18.3, module version = 0.19.0[    37.784] Module class: X.Org XInput Driver[    37.784] ABI class: X.Org XInput driver, version 22.1[    37.784] (II) Using input driver 'libinput' for 'Power Button'[    37.784] (**) Power Button: always reports core events[    37.784] (**) Option "Device" "/dev/input/event4"[    37.784] (**) Option "_source" "server/udev"[    37.785] (II) input device 'Power Button', /dev/input/event4 is tagged by udev as: Keyboard[    37.785] (II) input device 'Power Button', /dev/input/event4 is a keyboard[    37.800] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input7/event4"[    37.800] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)[    37.800] (**) Option "xkb_model" "pc105"[    37.800] (**) Option "xkb_layout" "fr"[    37.800] (**) Option "xkb_variant" "latin9"[    37.828] (II) input device 'Power Button', /dev/input/event4 is tagged by udev as: Keyboard[    37.828] (II) input device 'Power Button', /dev/input/event4 is a keyboard[    37.828] (II) config/udev: Adding input device Power Button (/dev/input/event3)[    37.828] (**) Power Button: Applying InputClass "evdev keyboard catchall"[    37.828] (**) Power Button: Applying InputClass "libinput keyboard catchall"[    37.828] (II) Using input driver 'libinput' for 'Power Button'[    37.828] (**) Power Button: always reports core events[    37.828] (**) Option "Device" "/dev/input/event3"[    37.828] (**) Option "_source" "server/udev"[    37.828] (II) input device 'Power Button', /dev/input/event3 is tagged by udev as: Keyboard[    37.828] (II) input device 'Power Button', /dev/input/event3 is a keyboard[    37.852] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input6/event3"[    37.852] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)[    37.852] (**) Option "xkb_model" "pc105"[    37.852] (**) Option "xkb_layout" "fr"[    37.852] (**) Option "xkb_variant" "latin9"[    37.852] (II) input device 'Power Button', /dev/input/event3 is tagged by udev as: Keyboard[    37.852] (II) input device 'Power Button', /dev/input/event3 is a keyboard[    37.853] (II) config/udev: Adding input device HDA ATI HDMI HDMI/DP,pcm=3 (/dev/input/event5)[    37.853] (II) No input driver specified, ignoring this device.[    37.853] (II) This device may have been added with another device file.[    37.853] (II) config/udev: Adding input device HDA Intel PCH Rear Mic (/dev/input/event7)[    37.853] (II) No input driver specified, ignoring this device.[    37.853] (II) This device may have been added with another device file.[    37.854] (II) config/udev: Adding input device HDA Intel PCH Front Mic (/dev/input/event[    37.854] (II) No input driver specified, ignoring this device.[    37.854] (II) This device may have been added with another device file.[    37.854] (II) config/udev: Adding input device HDA Intel PCH Line Out (/dev/input/event9)[    37.854] (II) No input driver specified, ignoring this device.[    37.854] (II) This device may have been added with another device file.[    37.854] (II) config/udev: Adding input device HDA Intel PCH Front Headphone (/dev/input/event10)[    37.854] (II) No input driver specified, ignoring this device.[    37.854] (II) This device may have been added with another device file.[    37.855] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event6)[    37.855] (II) No input driver specified, ignoring this device.[    37.855] (II) This device may have been added with another device file.[    37.855] (II) config/udev: Adding input device Microsoft Microsoft® Digital Media Keyboard 3000 (/dev/input/event0)[    37.855] (**) Microsoft Microsoft® Digital Media Keyboard 3000: Applying InputClass "evdev keyboard catchall"[    37.855] (**) Microsoft Microsoft® Digital Media Keyboard 3000: Applying InputClass "libinput keyboard catchall"[    37.855] (II) Using input driver 'libinput' for 'Microsoft Microsoft® Digital Media Keyboard 3000'[    37.855] (**) Microsoft Microsoft® Digital Media Keyboard 3000: always reports core events[    37.855] (**) Option "Device" "/dev/input/event0"[    37.855] (**) Option "_source" "server/udev"[    37.856] (II) input device 'Microsoft Microsoft® Digital Media Keyboard 3000', /dev/input/event0 is tagged by udev as: Keyboard[    37.856] (II) input device 'Microsoft Microsoft® Digital Media Keyboard 3000', /dev/input/event0 is a keyboard[    37.876] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.4/2-1.4.1/2-1.4.1:1.0/0003:045E:0730.0001/input/input3/event0"[    37.876] (II) XINPUT: Adding extended input device "Microsoft Microsoft® Digital Media Keyboard 3000" (type: KEYBOARD, id [    37.876] (**) Option "xkb_model" "pc105"[    37.876] (**) Option "xkb_layout" "fr"[    37.876] (**) Option "xkb_variant" "latin9"[    37.876] (II) input device 'Microsoft Microsoft® Digital Media Keyboard 3000', /dev/input/event0 is tagged by udev as: Keyboard[    37.876] (II) input device 'Microsoft Microsoft® Digital Media Keyboard 3000', /dev/input/event0 is a keyboard[    37.877] (II) config/udev: Adding input device Microsoft Microsoft® Digital Media Keyboard 3000 (/dev/input/event1)[    37.877] (**) Microsoft Microsoft® Digital Media Keyboard 3000: Applying InputClass "evdev keyboard catchall"[    37.877] (**) Microsoft Microsoft® Digital Media Keyboard 3000: Applying InputClass "libinput keyboard catchall"[    37.877] (II) Using input driver 'libinput' for 'Microsoft Microsoft® Digital Media Keyboard 3000'[    37.877] (**) Microsoft Microsoft® Digital Media Keyboard 3000: always reports core events[    37.877] (**) Option "Device" "/dev/input/event1"[    37.877] (**) Option "_source" "server/udev"[    37.878] (II) input device 'Microsoft Microsoft® Digital Media Keyboard 3000', /dev/input/event1 is tagged by udev as: Keyboard[    37.878] (II) input device 'Microsoft Microsoft® Digital Media Keyboard 3000', /dev/input/event1 is a keyboard[    37.888] (II) libinput: Microsoft Microsoft® Digital Media Keyboard 3000: needs a virtual subdevice[    37.888] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.4/2-1.4.1/2-1.4.1:1.1/0003:045E:0730.0002/input/input4/event1"[    37.888] (II) XINPUT: Adding extended input device "Microsoft Microsoft® Digital Media Keyboard 3000" (type: MOUSE, id 9)[    37.888] (**) Option "AccelerationScheme" "none"[    37.888] (**) Microsoft Microsoft® Digital Media Keyboard 3000: (accel) selected scheme none/0[    37.888] (**) Microsoft Microsoft® Digital Media Keyboard 3000: (accel) acceleration factor: 2.000[    37.888] (**) Microsoft Microsoft® Digital Media Keyboard 3000: (accel) acceleration threshold: 4[    37.888] (II) input device 'Microsoft Microsoft® Digital Media Keyboard 3000', /dev/input/event1 is tagged by udev as: Keyboard[    37.888] (II) input device 'Microsoft Microsoft® Digital Media Keyboard 3000', /dev/input/event1 is a keyboard[    37.889] (II) config/udev: Adding input device USB Optical Mouse (/dev/input/event11)[    37.889] (**) USB Optical Mouse: Applying InputClass "evdev pointer catchall"[    37.889] (**) USB Optical Mouse: Applying InputClass "libinput pointer catchall"[    37.889] (II) Using input driver 'libinput' for 'USB Optical Mouse'[    37.889] (**) USB Optical Mouse: always reports core events[    37.889] (**) Option "Device" "/dev/input/event11"[    37.889] (**) Option "_source" "server/udev"[    37.889] (II) input device 'USB Optical Mouse', /dev/input/event11 is tagged by udev as: Mouse[    37.889] (II) input device 'USB Optical Mouse', /dev/input/event11 is a pointer caps[    37.928] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.4/2-1.4.2/2-1.4.2:1.0/0003:1BCF:0005.0003/input/input14/event11"[    37.928] (II) XINPUT: Adding extended input device "USB Optical Mouse" (type: MOUSE, id 10)[    37.928] (**) Option "AccelerationScheme" "none"[    37.928] (**) USB Optical Mouse: (accel) selected scheme none/0[    37.928] (**) USB Optical Mouse: (accel) acceleration factor: 2.000[    37.928] (**) USB Optical Mouse: (accel) acceleration threshold: 4[    37.928] (II) input device 'USB Optical Mouse', /dev/input/event11 is tagged by udev as: Mouse[    37.928] (II) input device 'USB Optical Mouse', /dev/input/event11 is a pointer caps[    37.929] (II) config/udev: Adding input device USB Optical Mouse (/dev/input/mouse0)[    37.929] (II) No input driver specified, ignoring this device.[    37.929] (II) This device may have been added with another device file.[    37.929] (II) config/udev: Adding input device PC Speaker (/dev/input/event2)[    37.929] (II) No input driver specified, ignoring this device.[    37.929] (II) This device may have been added with another device file.[    37.933] (**) Microsoft Microsoft® Digital Media Keyboard 3000: Applying InputClass "evdev keyboard catchall"[    37.933] (**) Microsoft Microsoft® Digital Media Keyboard 3000: Applying InputClass "libinput keyboard catchall"[    37.933] (II) Using input driver 'libinput' for 'Microsoft Microsoft® Digital Media Keyboard 3000'[    37.933] (**) Microsoft Microsoft® Digital Media Keyboard 3000: always reports core events[    37.933] (**) Option "Device" "/dev/input/event1"[    37.933] (**) Option "_source" "_driver/libinput"[    37.933] (II) libinput: Microsoft Microsoft® Digital Media Keyboard 3000: is a virtual subdevice[    37.933] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.4/2-1.4.1/2-1.4.1:1.1/0003:045E:0730.0002/input/input4/event1"[    37.933] (II) XINPUT: Adding extended input device "Microsoft Microsoft® Digital Media Keyboard 3000" (type: KEYBOARD, id 11)[    37.933] (**) Option "xkb_model" "pc105"[    37.933] (**) Option "xkb_layout" "fr"[    37.933] (**) Option "xkb_variant" "latin9"[    74.488] (II) modeset(0): EDID vendor "DEL", prod id 41082[    74.488] (II) modeset(0): Using EDID range info for horizontal sync[    74.488] (II) modeset(0): Using EDID range info for vertical refresh[    74.488] (II) modeset(0): Printing DDC gathered Modelines:[    74.488] (II) modeset(0): Modeline "1920x1200"x0.0  154.00  1920 1968 2000 2080  1200 1203 1209 1235 +hsync -vsync (74.0 kHz eP)[    74.488] (II) modeset(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)[    74.488] (II) modeset(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)[    74.488] (II) modeset(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)[    74.488] (II) modeset(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)[    74.488] (II) modeset(0): Modeline "1280x960"x0.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)[    74.488] (II) modeset(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)[    74.488] (II) modeset(0): Modeline "1600x1200"x0.0  162.00  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)[    74.488] (II) modeset(0): Modeline "1680x1050"x0.0  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)[    74.488] (II) modeset(0): Modeline "1920x1080"x60.0  172.80  1920 2040 2248 2576  1080 1081 1084 1118 -hsync +vsync (67.1 kHz e)[    85.772] (II) modeset(0): EDID vendor "DEL", prod id 41082[    85.772] (II) modeset(0): Using hsync ranges from config file[    85.772] (II) modeset(0): Using vrefresh ranges from config file[    85.772] (II) modeset(0): Printing DDC gathered Modelines:[    85.772] (II) modeset(0): Modeline "1920x1200"x0.0  154.00  1920 1968 2000 2080  1200 1203 1209 1235 +hsync -vsync (74.0 kHz eP)[    85.772] (II) modeset(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)[    85.772] (II) modeset(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)[    85.772] (II) modeset(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)[    85.772] (II) modeset(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)[    85.772] (II) modeset(0): Modeline "1280x960"x0.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)[    85.772] (II) modeset(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)[    85.772] (II) modeset(0): Modeline "1600x1200"x0.0  162.00  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)[    85.772] (II) modeset(0): Modeline "1680x1050"x0.0  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)[    85.772] (II) modeset(0): Modeline "1920x1080"x60.0  172.80  1920 2040 2248 2576  1080 1081 1084 1118 -hsync +vsync (67.1 kHz e)[    85.832] (II) modeset(0): EDID vendor "DEL", prod id 41082[    85.832] (II) modeset(0): Using hsync ranges from config file[    85.832] (II) modeset(0): Using vrefresh ranges from config file[    85.832] (II) modeset(0): Printing DDC gathered Modelines:[    85.832] (II) modeset(0): Modeline "1920x1200"x0.0  154.00  1920 1968 2000 2080  1200 1203 1209 1235 +hsync -vsync (74.0 kHz eP)[    85.832] (II) modeset(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)[    85.832] (II) modeset(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)[    85.832] (II) modeset(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)[    85.832] (II) modeset(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)[    85.832] (II) modeset(0): Modeline "1280x960"x0.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)[    85.832] (II) modeset(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)[    85.832] (II) modeset(0): Modeline "1600x1200"x0.0  162.00  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)[    85.832] (II) modeset(0): Modeline "1680x1050"x0.0  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)[    85.832] (II) modeset(0): Modeline "1920x1080"x60.0  172.80  1920 2040 2248 2576  1080 1081 1084 1118 -hsync +vsync (67.1 kHz e)[   175.963] (II) modeset(0): EDID vendor "DEL", prod id 41082[   175.963] (II) modeset(0): Using hsync ranges from config file[   175.963] (II) modeset(0): Using vrefresh ranges from config file[   175.963] (II) modeset(0): Printing DDC gathered Modelines:[   175.963] (II) modeset(0): Modeline "1920x1200"x0.0  154.00  1920 1968 2000 2080  1200 1203 1209 1235 +hsync -vsync (74.0 kHz eP)[   175.963] (II) modeset(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)[   175.963] (II) modeset(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)[   175.963] (II) modeset(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)[   175.963] (II) modeset(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)[   175.963] (II) modeset(0): Modeline "1280x960"x0.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)[   175.963] (II) modeset(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)[   175.963] (II) modeset(0): Modeline "1600x1200"x0.0  162.00  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)[   175.963] (II) modeset(0): Modeline "1680x1050"x0.0  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)[   175.963] (II) modeset(0): Modeline "1920x1080"x60.0  172.80  1920 2040 2248 2576  1080 1081 1084 1118 -hsync +vsync (67.1 kHz e)[ 25501.199] (II) SYN_DROPPED event from "USB Optical Mouse" - some input events have been lost.[ 25504.225] (II) SYN_DROPPED event from "USB Optical Mouse" - some input events have been lost.[ 25979.736] (II) SYN_DROPPED event from "USB Optical Mouse" - some input events have been lost.[ 26034.648] (II) SYN_DROPPED event from "USB Optical Mouse" - some input events have been lost.[ 26117.738] (II) SYN_DROPPED event from "USB Optical Mouse" - some input events have been lost.[ 26396.096] (II) SYN_DROPPED event from "USB Optical Mouse" - some input events have been lost.[ 26528.983] (II) SYN_DROPPED event from "USB Optical Mouse" - some input events have been lost.[447424.184] (II) modeset(0): EDID vendor "DEL", prod id 41082[447424.185] (II) modeset(0): Using hsync ranges from config file[447424.185] (II) modeset(0): Using vrefresh ranges from config file[447424.185] (II) modeset(0): Printing DDC gathered Modelines:[447424.185] (II) modeset(0): Modeline "1920x1200"x0.0  154.00  1920 1968 2000 2080  1200 1203 1209 1235 +hsync -vsync (74.0 kHz eP)[447424.185] (II) modeset(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)[447424.185] (II) modeset(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)[447424.185] (II) modeset(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)[447424.185] (II) modeset(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)[447424.185] (II) modeset(0): Modeline "1280x960"x0.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)[447424.185] (II) modeset(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)[447424.185] (II) modeset(0): Modeline "1600x1200"x0.0  162.00  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)[447424.185] (II) modeset(0): Modeline "1680x1050"x0.0  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)[447424.185] (II) modeset(0): Modeline "1920x1080"x60.0  172.80  1920 2040 2248 2576  1080 1081 1084 1118 -hsync +vsync (67.1 kHz e)[447424.247] (II) modeset(0): EDID vendor "DEL", prod id 41082[447424.247] (II) modeset(0): Using hsync ranges from config file[447424.247] (II) modeset(0): Using vrefresh ranges from config file[447424.247] (II) modeset(0): Printing DDC gathered Modelines:[447424.247] (II) modeset(0): Modeline "1920x1200"x0.0  154.00  1920 1968 2000 2080  1200 1203 1209 1235 +hsync -vsync (74.0 kHz eP)[447424.247] (II) modeset(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)[447424.247] (II) modeset(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)[447424.247] (II) modeset(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)[447424.247] (II) modeset(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)[447424.247] (II) modeset(0): Modeline "1280x960"x0.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)[447424.247] (II) modeset(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)[447424.247] (II) modeset(0): Modeline "1600x1200"x0.0  162.00  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)[447424.247] (II) modeset(0): Modeline "1680x1050"x0.0  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)[447424.247] (II) modeset(0): Modeline "1920x1080"x60.0  172.80  1920 2040 2248 2576  1080 1081 1084 1118 -hsync +vsync (67.1 kHz e)[447424.299] (II) modeset(0): EDID vendor "DEL", prod id 41082[447424.299] (II) modeset(0): Using hsync ranges from config file[447424.299] (II) modeset(0): Using vrefresh ranges from config file[447424.299] (II) modeset(0): Printing DDC gathered Modelines:[447424.299] (II) modeset(0): Modeline "1920x1200"x0.0  154.00  1920 1968 2000 2080  1200 1203 1209 1235 +hsync -vsync (74.0 kHz eP)[447424.299] (II) modeset(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)[447424.299] (II) modeset(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)[447424.299] (II) modeset(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)[447424.299] (II) modeset(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)[447424.299] (II) modeset(0): Modeline "1280x960"x0.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)[447424.299] (II) modeset(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)[447424.299] (II) modeset(0): Modeline "1600x1200"x0.0  162.00  1600 1664 1856 2160  1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)[447424.299] (II) modeset(0): Modeline "1680x1050"x0.0  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)[447424.299] (II) modeset(0): Modeline "1920x1080"x60.0  172.80  1920 2040 2248 2576  1080 1081 1084 1118 -hsync +vsync (67.1 kHz e)
and  the output of glxinfo:
name of display: :0.0display: :0  screen: 0direct rendering: Yesserver glx vendor string: SGIserver glx version string: 1.4server glx extensions:   GLX_ARB_create_context, GLX_ARB_create_context_profile,    GLX_ARB_create_context_robustness, GLX_ARB_fbconfig_float,    GLX_ARB_framebuffer_sRGB, GLX_ARB_multisample,    GLX_EXT_create_context_es2_profile, GLX_EXT_create_context_es_profile,    GLX_EXT_fbconfig_packed_float, GLX_EXT_framebuffer_sRGB,    GLX_EXT_import_context, GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info,    GLX_EXT_visual_rating, GLX_INTEL_swap_event, GLX_MESA_copy_sub_buffer,    GLX_OML_swap_method, GLX_SGIS_multisample, GLX_SGIX_fbconfig,    GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group, GLX_SGI_swap_controlclient glx vendor string: Mesa Project and SGIclient glx version string: 1.4client glx extensions:   GLX_ARB_create_context, GLX_ARB_create_context_profile,    GLX_ARB_create_context_robustness, GLX_ARB_fbconfig_float,    GLX_ARB_framebuffer_sRGB, GLX_ARB_get_proc_address, GLX_ARB_multisample,    GLX_EXT_buffer_age, GLX_EXT_create_context_es2_profile,    GLX_EXT_create_context_es_profile, GLX_EXT_fbconfig_packed_float,    GLX_EXT_framebuffer_sRGB, GLX_EXT_import_context,    GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info, GLX_EXT_visual_rating,    GLX_INTEL_swap_event, GLX_MESA_copy_sub_buffer,    GLX_MESA_multithread_makecurrent, GLX_MESA_query_renderer,    GLX_MESA_swap_control, GLX_OML_swap_method, GLX_OML_sync_control,    GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,    GLX_SGIX_visual_select_group, GLX_SGI_make_current_read,    GLX_SGI_swap_control, GLX_SGI_video_syncGLX version: 1.4GLX extensions:   GLX_ARB_create_context, GLX_ARB_create_context_profile,    GLX_ARB_create_context_robustness, GLX_ARB_fbconfig_float,    GLX_ARB_framebuffer_sRGB, GLX_ARB_get_proc_address, GLX_ARB_multisample,    GLX_EXT_buffer_age, GLX_EXT_create_context_es2_profile,    GLX_EXT_create_context_es_profile, GLX_EXT_fbconfig_packed_float,    GLX_EXT_framebuffer_sRGB, GLX_EXT_import_context,    GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info, GLX_EXT_visual_rating,    GLX_INTEL_swap_event, GLX_MESA_copy_sub_buffer,    GLX_MESA_multithread_makecurrent, GLX_MESA_query_renderer,    GLX_MESA_swap_control, GLX_OML_swap_method, GLX_OML_sync_control,    GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,    GLX_SGIX_visual_select_group, GLX_SGI_make_current_read,    GLX_SGI_swap_control, GLX_SGI_video_syncExtended renderer info (GLX_MESA_query_renderer):   Vendor: X.Org (0x1002)   Device: AMD CAICOS (DRM 2.43.0, LLVM 3.8.0) (0x6779)   Version: 11.2.2   Accelerated: yes   Video memory: 1024MB   Unified memory: no   Preferred profile: core (0x1)   Max core profile version: 3.3   Max compat profile version: 3.0   Max GLES1 profile version: 1.1   Max GLES[23] profile version: 3.0OpenGL vendor string: X.OrgOpenGL renderer string: Gallium 0.4 on AMD CAICOS (DRM 2.43.0, LLVM 3.8.0)OpenGL core profile version string: 3.3 (Core Profile) Mesa 11.2.2OpenGL core profile shading language version string: 3.30OpenGL core profile context flags: (none)OpenGL core profile profile mask: core profileOpenGL core profile extensions:   GL_AMD_conservative_depth, GL_AMD_draw_buffers_blend,    GL_AMD_performance_monitor, GL_AMD_pinned_memory,    GL_AMD_seamless_cubemap_per_texture, GL_AMD_shader_stencil_export,    GL_AMD_shader_trinary_minmax, GL_AMD_vertex_shader_layer,    GL_AMD_vertex_shader_viewport_index, GL_ANGLE_texture_compression_dxt3,    GL_ANGLE_texture_compression_dxt5, GL_ARB_ES2_compatibility,    GL_ARB_ES3_compatibility, GL_ARB_arrays_of_arrays, GL_ARB_base_instance,    GL_ARB_blend_func_extended, GL_ARB_buffer_storage,    GL_ARB_clear_buffer_object, GL_ARB_clip_control,    GL_ARB_compressed_texture_pixel_storage,    GL_ARB_conditional_render_inverted, GL_ARB_conservative_depth,    GL_ARB_copy_buffer, GL_ARB_copy_image, GL_ARB_debug_output,    GL_ARB_depth_buffer_float, GL_ARB_depth_clamp, GL_ARB_derivative_control,    GL_ARB_direct_state_access, GL_ARB_draw_buffers,    GL_ARB_draw_buffers_blend, GL_ARB_draw_elements_base_vertex,    GL_ARB_draw_indirect, GL_ARB_draw_instanced,    GL_ARB_explicit_attrib_location, GL_ARB_explicit_uniform_location,    GL_ARB_fragment_coord_conventions, GL_ARB_fragment_layer_viewport,    GL_ARB_fragment_shader, GL_ARB_framebuffer_object,    GL_ARB_framebuffer_sRGB, GL_ARB_get_program_binary,    GL_ARB_get_texture_sub_image, GL_ARB_gpu_shader5, GL_ARB_half_float_pixel,    GL_ARB_half_float_vertex, GL_ARB_instanced_arrays,    GL_ARB_internalformat_query, GL_ARB_invalidate_subdata,    GL_ARB_map_buffer_alignment, GL_ARB_map_buffer_range, GL_ARB_multi_bind,    GL_ARB_multi_draw_indirect, GL_ARB_occlusion_query2,    GL_ARB_pipeline_statistics_query, GL_ARB_pixel_buffer_object,    GL_ARB_point_sprite, GL_ARB_program_interface_query,    GL_ARB_provoking_vertex, GL_ARB_robustness, GL_ARB_sample_shading,    GL_ARB_sampler_objects, GL_ARB_seamless_cube_map,    GL_ARB_seamless_cubemap_per_texture, GL_ARB_separate_shader_objects,    GL_ARB_shader_bit_encoding, GL_ARB_shader_objects,    GL_ARB_shader_precision, GL_ARB_shader_stencil_export,    GL_ARB_shader_subroutine, GL_ARB_shader_texture_image_samples,    GL_ARB_shader_texture_lod, GL_ARB_shading_language_420pack,    GL_ARB_shading_language_packing, GL_ARB_stencil_texturing, GL_ARB_sync,    GL_ARB_tessellation_shader, GL_ARB_texture_barrier,    GL_ARB_texture_buffer_object, GL_ARB_texture_buffer_object_rgb32,    GL_ARB_texture_buffer_range, GL_ARB_texture_compression_bptc,    GL_ARB_texture_compression_rgtc, GL_ARB_texture_cube_map_array,    GL_ARB_texture_float, GL_ARB_texture_gather,    GL_ARB_texture_mirror_clamp_to_edge, GL_ARB_texture_multisample,    GL_ARB_texture_non_power_of_two, GL_ARB_texture_query_levels,    GL_ARB_texture_query_lod, GL_ARB_texture_rectangle, GL_ARB_texture_rg,    GL_ARB_texture_rgb10_a2ui, GL_ARB_texture_stencil8,    GL_ARB_texture_storage, GL_ARB_texture_storage_multisample,    GL_ARB_texture_swizzle, GL_ARB_texture_view, GL_ARB_timer_query,    GL_ARB_transform_feedback2, GL_ARB_transform_feedback3,    GL_ARB_transform_feedback_instanced, GL_ARB_uniform_buffer_object,    GL_ARB_vertex_array_bgra, GL_ARB_vertex_array_object,    GL_ARB_vertex_attrib_binding, GL_ARB_vertex_shader,    GL_ARB_vertex_type_10f_11f_11f_rev, GL_ARB_vertex_type_2_10_10_10_rev,    GL_ARB_viewport_array, GL_ATI_blend_equation_separate, GL_ATI_meminfo,    GL_ATI_texture_float, GL_ATI_texture_mirror_once, GL_EXT_abgr,    GL_EXT_blend_equation_separate, GL_EXT_draw_buffers2,    GL_EXT_draw_instanced, GL_EXT_framebuffer_blit,    GL_EXT_framebuffer_multisample, GL_EXT_framebuffer_multisample_blit_scaled,    GL_EXT_framebuffer_sRGB, GL_EXT_packed_depth_stencil, GL_EXT_packed_float,    GL_EXT_pixel_buffer_object, GL_EXT_polygon_offset_clamp,    GL_EXT_provoking_vertex, GL_EXT_shader_integer_mix, GL_EXT_texture_array,    GL_EXT_texture_compression_dxt1, GL_EXT_texture_compression_rgtc,    GL_EXT_texture_compression_s3tc, GL_EXT_texture_filter_anisotropic,    GL_EXT_texture_integer, GL_EXT_texture_mirror_clamp, GL_EXT_texture_sRGB,    GL_EXT_texture_sRGB_decode, GL_EXT_texture_shared_exponent,    GL_EXT_texture_snorm, GL_EXT_texture_swizzle, GL_EXT_timer_query,    GL_EXT_transform_feedback, GL_EXT_vertex_array_bgra,    GL_IBM_multimode_draw_arrays, GL_KHR_context_flush_control, GL_KHR_debug,    GL_MESA_pack_invert, GL_MESA_texture_signed_rgba, GL_NVX_gpu_memory_info,    GL_NV_conditional_render, GL_NV_depth_clamp, GL_NV_packed_depth_stencil,    GL_NV_texture_barrier, GL_NV_vdpau_interop, GL_OES_EGL_image,    GL_OES_read_format, GL_S3_s3tcOpenGL version string: 3.0 Mesa 11.2.2OpenGL shading language version string: 1.30OpenGL context flags: (none)OpenGL extensions:   GL_AMD_conservative_depth, GL_AMD_draw_buffers_blend,    GL_AMD_performance_monitor, GL_AMD_pinned_memory,    GL_AMD_seamless_cubemap_per_texture, GL_AMD_shader_stencil_export,    GL_AMD_shader_trinary_minmax, GL_ANGLE_texture_compression_dxt3,    GL_ANGLE_texture_compression_dxt5, GL_APPLE_packed_pixels,    GL_APPLE_vertex_array_object, GL_ARB_ES2_compatibility,    GL_ARB_ES3_compatibility, GL_ARB_arrays_of_arrays, GL_ARB_base_instance,    GL_ARB_blend_func_extended, GL_ARB_buffer_storage,    GL_ARB_clear_buffer_object, GL_ARB_clip_control,    GL_ARB_color_buffer_float, GL_ARB_compressed_texture_pixel_storage,    GL_ARB_conditional_render_inverted, GL_ARB_conservative_depth,    GL_ARB_copy_buffer, GL_ARB_copy_image, GL_ARB_debug_output,    GL_ARB_depth_buffer_float, GL_ARB_depth_clamp, GL_ARB_depth_texture,    GL_ARB_derivative_control, GL_ARB_draw_buffers, GL_ARB_draw_buffers_blend,    GL_ARB_draw_elements_base_vertex, GL_ARB_draw_instanced,    GL_ARB_explicit_attrib_location, GL_ARB_explicit_uniform_location,    GL_ARB_fragment_coord_conventions, GL_ARB_fragment_program,    GL_ARB_fragment_program_shadow, GL_ARB_fragment_shader,    GL_ARB_framebuffer_object, GL_ARB_framebuffer_sRGB,    GL_ARB_get_program_binary, GL_ARB_get_texture_sub_image,    GL_ARB_half_float_pixel, GL_ARB_half_float_vertex,    GL_ARB_instanced_arrays, GL_ARB_internalformat_query,    GL_ARB_invalidate_subdata, GL_ARB_map_buffer_alignment,    GL_ARB_map_buffer_range, GL_ARB_multi_bind, GL_ARB_multisample,    GL_ARB_multitexture, GL_ARB_occlusion_query, GL_ARB_occlusion_query2,    GL_ARB_pipeline_statistics_query, GL_ARB_pixel_buffer_object,    GL_ARB_point_parameters, GL_ARB_point_sprite,    GL_ARB_program_interface_query, GL_ARB_provoking_vertex,    GL_ARB_robustness, GL_ARB_sample_shading, GL_ARB_sampler_objects,    GL_ARB_seamless_cube_map, GL_ARB_seamless_cubemap_per_texture,    GL_ARB_separate_shader_objects, GL_ARB_shader_bit_encoding,    GL_ARB_shader_objects, GL_ARB_shader_precision,    GL_ARB_shader_stencil_export, GL_ARB_shader_texture_image_samples,    GL_ARB_shader_texture_lod, GL_ARB_shading_language_100,    GL_ARB_shading_language_420pack, GL_ARB_shading_language_packing,    GL_ARB_shadow, GL_ARB_stencil_texturing, GL_ARB_sync,    GL_ARB_texture_barrier, GL_ARB_texture_border_clamp,    GL_ARB_texture_compression, GL_ARB_texture_compression_bptc,    GL_ARB_texture_compression_rgtc, GL_ARB_texture_cube_map,    GL_ARB_texture_cube_map_array, GL_ARB_texture_env_add,    GL_ARB_texture_env_combine, GL_ARB_texture_env_crossbar,    GL_ARB_texture_env_dot3, GL_ARB_texture_float, GL_ARB_texture_gather,    GL_ARB_texture_mirror_clamp_to_edge, GL_ARB_texture_mirrored_repeat,    GL_ARB_texture_multisample, GL_ARB_texture_non_power_of_two,    GL_ARB_texture_query_levels, GL_ARB_texture_query_lod,    GL_ARB_texture_rectangle, GL_ARB_texture_rg, GL_ARB_texture_rgb10_a2ui,    GL_ARB_texture_stencil8, GL_ARB_texture_storage,    GL_ARB_texture_storage_multisample, GL_ARB_texture_swizzle,    GL_ARB_texture_view, GL_ARB_timer_query, GL_ARB_transform_feedback2,    GL_ARB_transform_feedback3, GL_ARB_transform_feedback_instanced,    GL_ARB_transpose_matrix, GL_ARB_uniform_buffer_object,    GL_ARB_vertex_array_bgra, GL_ARB_vertex_array_object,    GL_ARB_vertex_attrib_binding, GL_ARB_vertex_buffer_object,    GL_ARB_vertex_program, GL_ARB_vertex_shader,    GL_ARB_vertex_type_10f_11f_11f_rev, GL_ARB_vertex_type_2_10_10_10_rev,    GL_ARB_window_pos, GL_ATI_blend_equation_separate, GL_ATI_draw_buffers,    GL_ATI_meminfo, GL_ATI_separate_stencil, GL_ATI_texture_compression_3dc,    GL_ATI_texture_env_combine3, GL_ATI_texture_float,    GL_ATI_texture_mirror_once, GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color,    GL_EXT_blend_equation_separate, GL_EXT_blend_func_separate,    GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_compiled_vertex_array,    GL_EXT_copy_texture, GL_EXT_draw_buffers2, GL_EXT_draw_instanced,    GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_framebuffer_blit,    GL_EXT_framebuffer_multisample, GL_EXT_framebuffer_multisample_blit_scaled,    GL_EXT_framebuffer_object, GL_EXT_framebuffer_sRGB,    GL_EXT_gpu_program_parameters, GL_EXT_multi_draw_arrays,    GL_EXT_packed_depth_stencil, GL_EXT_packed_float, GL_EXT_packed_pixels,    GL_EXT_pixel_buffer_object, GL_EXT_point_parameters,    GL_EXT_polygon_offset, GL_EXT_polygon_offset_clamp,    GL_EXT_provoking_vertex, GL_EXT_rescale_normal, GL_EXT_secondary_color,    GL_EXT_separate_specular_color, GL_EXT_shader_integer_mix,    GL_EXT_shadow_funcs, GL_EXT_stencil_two_side, GL_EXT_stencil_wrap,    GL_EXT_subtexture, GL_EXT_texture, GL_EXT_texture3D,    GL_EXT_texture_array, GL_EXT_texture_compression_dxt1,    GL_EXT_texture_compression_latc, GL_EXT_texture_compression_rgtc,    GL_EXT_texture_compression_s3tc, GL_EXT_texture_cube_map,    GL_EXT_texture_edge_clamp, GL_EXT_texture_env_add,    GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3,    GL_EXT_texture_filter_anisotropic, GL_EXT_texture_integer,    GL_EXT_texture_lod_bias, GL_EXT_texture_mirror_clamp,    GL_EXT_texture_object, GL_EXT_texture_rectangle, GL_EXT_texture_sRGB,    GL_EXT_texture_sRGB_decode, GL_EXT_texture_shared_exponent,    GL_EXT_texture_snorm, GL_EXT_texture_swizzle, GL_EXT_timer_query,    GL_EXT_transform_feedback, GL_EXT_vertex_array, GL_EXT_vertex_array_bgra,    GL_IBM_multimode_draw_arrays, GL_IBM_rasterpos_clip,    GL_IBM_texture_mirrored_repeat, GL_INGR_blend_func_separate,    GL_KHR_context_flush_control, GL_KHR_debug, GL_MESA_pack_invert,    GL_MESA_texture_signed_rgba, GL_MESA_window_pos, GL_NVX_gpu_memory_info,    GL_NV_blend_square, GL_NV_conditional_render, GL_NV_depth_clamp,    GL_NV_fog_distance, GL_NV_light_max_exponent, GL_NV_packed_depth_stencil,    GL_NV_primitive_restart, GL_NV_texgen_reflection, GL_NV_texture_barrier,    GL_NV_texture_env_combine4, GL_NV_texture_rectangle, GL_NV_vdpau_interop,    GL_OES_EGL_image, GL_OES_read_format, GL_S3_s3tc,    GL_SGIS_generate_mipmap, GL_SGIS_texture_border_clamp,    GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod, GL_SUN_multi_draw_arraysOpenGL ES profile version string: OpenGL ES 3.0 Mesa 11.2.2OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.00OpenGL ES profile extensions:   GL_ANGLE_texture_compression_dxt3, GL_ANGLE_texture_compression_dxt5,    GL_APPLE_texture_max_level, GL_EXT_blend_func_extended,    GL_EXT_blend_minmax, GL_EXT_color_buffer_float,    GL_EXT_discard_framebuffer, GL_EXT_draw_buffers,    GL_EXT_draw_elements_base_vertex, GL_EXT_map_buffer_range,    GL_EXT_multi_draw_arrays, GL_EXT_read_format_bgra,    GL_EXT_separate_shader_objects, GL_EXT_shader_integer_mix,    GL_EXT_texture_compression_dxt1, GL_EXT_texture_filter_anisotropic,    GL_EXT_texture_format_BGRA8888, GL_EXT_texture_rg,    GL_EXT_texture_type_2_10_10_10_REV, GL_EXT_unpack_subimage,    GL_KHR_context_flush_control, GL_KHR_debug, GL_NV_draw_buffers,    GL_NV_fbo_color_attachments, GL_NV_read_buffer, GL_NV_read_depth,    GL_NV_read_depth_stencil, GL_NV_read_stencil, GL_OES_EGL_image,    GL_OES_EGL_image_external, GL_OES_EGL_sync,    GL_OES_compressed_ETC1_RGB8_texture, GL_OES_depth24, GL_OES_depth_texture,    GL_OES_depth_texture_cube_map, GL_OES_draw_elements_base_vertex,    GL_OES_element_index_uint, GL_OES_fbo_render_mipmap,    GL_OES_get_program_binary, GL_OES_mapbuffer, GL_OES_packed_depth_stencil,    GL_OES_rgb8_rgba8, GL_OES_standard_derivatives, GL_OES_stencil8,    GL_OES_surfaceless_context, GL_OES_texture_3D, GL_OES_texture_float,    GL_OES_texture_float_linear, GL_OES_texture_half_float,    GL_OES_texture_half_float_linear, GL_OES_texture_npot,    GL_OES_texture_stencil8, GL_OES_vertex_array_object
Any idea what's going on?
Thanks,
Frédéric
        • 6 replies
