Posted · Communicating settings to each other.
Is the best way to save a profile (ini) file and to copy from there ?
Or should it be a feature in Cura ?
nozzle_size = 0.4
layer_height = 0.2
wall_thickness = 0.8
retraction_enable = False
solid_layer_thickness = 0.6
fill_density = 20
skirt_line_count = 2
skirt_gap = 3.0
print_speed = 20
print_temperature = 230
support = None
enable_raft = False
filament_density = 1.00
retraction_min_travel = 5.0
retraction_speed = 40.0
retraction_amount = 4.5
retraction_extra = 0.0
travel_speed = 150
max_z_speed = 3.0
bottom_layer_speed = 20
cool_min_layer_time = 10
fan_enabled = True
bottom_thickness = 0.3
enable_skin = False
extra_base_wall_thickness = 0.0
cool_min_feedrate = 10
fan_layer = 1
fan_speed = 100
fan_speed_max = 100
raft_margin = 5
raft_base_material_amount = 100
raft_interface_material_amount = 100
support_rate = 50
support_distance = 0.5
infill_type = Line
solid_top = True
fill_overlap = 15
bridge_speed = 100
sequence = Loops > Perimeter > Infill
force_first_layer_sequence = True
joris = False
retract_on_jumps_only = True
