Does cura 2.1.3 still able to use the pause at height Plugins
printedman
  • 4 months later...
Posted · Does cura 2.1.3 still able to use the pause at height Plugins
Extensions > Post Processing > Modify G-Code
THKs
But it only work on the last layer. Even if the parameters are changed.
And can't see the pause layer like 15.X in layers view.
Is there something wrong ?
    • 3 weeks later...
    Ufortunately it doesn't work on my UM3 either. It adds following lines to the Gcode, but nothing happens. Would be great if somebody knew what to do. Thanks in advance!
    ;POSTPROCESSED
    ;TYPE:CUSTOM
    ;added code by post processing
    ;script: PauseAtHeight.py
    ;current z: 4.000000
    M83
    G1 E-4.000000 F6000
    G1 Z5.000000 F300
    G1 X190.000000 Y190.000000 F9000
    G1 Z15 F300
    M84 E0
    M0 ;Do the actual pause
    G1 E4.000000 F6000
    G1 E-4.000000 F6000
    G1 Z5.000000 F300
    G1 X0.000000 Y0.000000 F9000
    G1 E4.000000 F6000
    G1 F9000
    M82
    G92 E-1.000000
    ;Generated with Cura_SteamEngine 2.3.1
