Posted · Beta stuck at slicing
I've tried everything i can think of and on 2.3 i'm not able to get anything past slicing, the progress bar doesn't move at all.
Any tips?
Restarting doesn't work. Changing all the settings doesn't work. I even added a new printer just for the heck of it and no luck.
    The beta has a bug that caused the configuration from Cura 2.1.x not being properly converted, leading to errors. In both the supplied logs I see symptoms of this problem. Could you rename or remove the C:\Users\YourUsername\AppData\Local\cura folder an try again? Unfortunately you will have to reconfigure your printer.
    Sorry for the late reply! I wasn't notified of replies.
    Deleting the cura folder seemed to solve the problem.
    I'd recommend everyone exporting their settings first, then just import when you open 2.3
