I don't know why sorry, but i've got a question... What is your 3D CAO software you used in the snapshot ?
Thank you Daid, I'll check into that.
It's tinkercad from
, I used it because I just want to draw a simple shape.
Hi Daid,
I did like u said, at first it works. But now it happened again, even worst. I'm suspected that maybe my belt misaligned, that makes the nozzle head hard to move, and stuck a bit on its journey, that lead to that situation. I will check my belt alignment. Other than that, do u hv any idea? I already tighten all the axes pulleys. Many thanks in advance
Could be under powered steppers, but this seems more likely a pulley, likely one of the ones physically on the stepper motor, not one of the axis pulleys. Those grub screws kinda split the torque, while the the one on the motor shaft is all by it's lonesome. Double check it. Then you should make sure your axis are parallel by loosening the pulleys on the axis and squaring up the print head spanners with the axis. Then lubricate the axis and spanners with a sewing machine oil, or similar substitute. That should make printhead movement much easier, and hopefully mean you won't have to adjust the stepper pots, because that can be dicey...
Hi MSURunner,
Yeh u right. 1 of my pulley attached to the motor was loose, so even the motor moves, but the nozzle head didn't move. I already tighten it and lubricated all the rods, and now it works good again. Thanks :mrgreen:
Daid 301
Most common cause of this is a lose pulley on one of the axes or the motor. (For the belts to "slip" they have to jump a tooth, which makes quite a bit of noise)
