Thermistors has never been used in Ultimaker printers, UMO used thermocouples and UM2/3 uses PT100 sensors, i would guess that the sensors are good for probably 400C, so higher temperature Print Cores (all metal made especially for some high-temp and not compatible with PLA etc) might very well be possible in the future.
From what i have seen, i would actually guess that the default Print Core can take quite a bit more than 280C without problems and that 280C is not operating it at its technical limits, even if 300+ probably would mean a reduced lifespan.
meduza 189
Basically it is a completly new design. It does incorporate a TFM sleeve, but it is isolated with a stainless heat break, so it is kept at much lower temperature (<100C) and should not degrade like the PTFE/TFM coupler on the UM2 series.
Lifespan... i would guess that we are talking about a pretty long time.
Daid 298
It's a different design.
There is TFM in there. But it's enclosed, you cannot see it. It's inside the cooling ribs. It's a really really cool design that makes sure the FTM isn't getting to hot, while it makes sure that PLA is not getting too cold at certain locations so that it locks up. (even during retractions)
The rest is just a shell, the heater+PT100 in a heater block, an EEPROM, a locking mechanism and a light guide.
JohnK 30
Thanks for the replies, sounds like a very interesting design.. Really looking forward to getting my printer
milehigh3dii 0
Is there anyway that print cores with higher temp limits could be made? Thermocouple versus thermistor? The physical parts in the heat zone are all metal, correct? That would be a great differentiator.
