DidierKlein 729
• What is the reason for the reduced print area?
The print area is the same as the Ultimaker 2 but if you use both cores (nozzles) it's reduced because the right core can't access the whole plate on the left and the left core can't access the whole plate on the right
• Can I use the same size spools as with UM2?
Yes!
• Can I use the same material (same color) in each printhead and if one runs out the other takes over?
Not automatically
• Will the printer know it's out of material and pause to let me reload?
No
• How soon after launch will other nozzles be available? I use 0.8 mm a lot.
I heard Q1 2017 for the .8mm nozzle (don't quote me on this )
• How long will I have to soak a model before the support dissolves?
Depends on the density, in cold water it takes around 10 - 12 hours
Add heat and movement and it can be reduced to less than 2 hours (even more)
• Is the overall printing speed the same as Ultimaker 2?
Yes but dual extrusion takes more time because of the switching and even more if you use a wipe tower
1
Top Posters In This Topic
6
4
5
3
Popular Days
Oct 24
18
Oct 21
12
Oct 20
7
Nov 18
4
nallath 6 posts
ultiarjan 4 posts
tinkergnome 5 posts
ClausJ 3 posts
Popular Days
Oct 24 2016
Oct 21 2016
Oct 20 2016
Nov 18 2016
Posted Images
nallath 1,080
Not at the moment. It could be possible to do this in the future.
Yes
Not at the moment.
Yep
