Thanks Daid! Also, has anyone used Cura with other printers besides Ultimaker?
I know it has gained significant traction in the RepRap world beyond UM, but I have yet to personally try it. It should function with any Marlin based firmware though.
Yes, quite a few actually. It works on most if not all RepRap designs if the printer runs Marlin or Sprinter.
Daid 305
While I've never tested it, I suspect you can run two instances at once and one will connect to one printer and the other will connect to the second.
