Pretty much the answer I was expecting haha. Looks like I'll have to restock my sandpaper
Support Material Leaves a texture
Try kisslicer, set the support gap to 0.6mm, and normally they will just break off in one lump or certainly large chunks using your thumbnail. It is also better with ABS I find than PLA.
IRobertI 503
Short answer, nope.
Longer answer. Since what you're trying to support needs to be in contact with the actual support it will leave marks no matter what you do. Experiment by rotating the object so that the side that needs to be pretty can be printed without support. Failing that it's time for sandpaper (the wet kind is best) and elbow grease.
