I have used helical couplings on several projects and never had any noticeable problem with them. You just don't want to put an axial load on them.
Getting rid of the short belts was about the best thing ever. Was such a pain to get the tension just right.
Top Posters In This Topic
35
19
14
12
Popular Days
May 23
9
Aug 19
8
Jun 6
8
Jan 13
7
foehnsturm 35 posts
snowygrouch 19 posts
zumfab 14 posts
lars86 12 posts
Popular Days
May 23 2013
Aug 19 2014
Jun 6 2013
Jan 13 2015
zumfab 3
It depends on what you call concerned. I do not mind couplers in general, but in this case they add a lot of bulk to the whole set-up and put the motors in a vulnerable position when moving the printer around. I think they are not really needed anyway. That is why I would prefer to eliminate them, not because of some inherent dislike for couplers in general
And if it does turn out to be the best solution to use them, I at least fiddled with it a bit and had some fun.
That is probably more of a discussion for the direct drive thread though.
Fair enough.
Edit: those cable tensioners work miracles. From sloppy prints with major issues to tight and smooth delight.
