I just bought a big box of flexible 5to8mm couplers.
They are not quite as good as the last ones I got, but I will replace the Z coupler
with one and see what happens.
I think also stiffer Bedplate springs will help. My table just flies around like those play toys in the park
which consist of a seat and handes on a big spring...
But I have a horrible suspicion that this will all lead to the inevitable...complete replacement of the Z stage.
What needs to happen to stabilize the bed (cantilevered design aside), is to take out the XY lash, while still allowing some give in Z. I'm thinking about mounting Oilite bushings (like the 8mm ones) vertically in the bed itself. Then bolting stubby shafts on the platform to ride in those bushings, with springs placed on each shaft pushing the bed away. The shafts would be drilled and tapped on the top surface to allow a flanged bolt from the top to set height.
I'm almost done with a complete top end rebuild tonight. I completely redesigned the hot end, and print head. The head is printed and includes an integrated 40mm fan shroud, which ducts air though a custom made heat sink on the stainless steel up-tube. Also, added MoonCactus' XY blocks.
Top Posters In This Topic
35
19
14
12
Popular Days
May 23
9
Aug 19
8
Jun 6
8
Jan 13
7
foehnsturm 35 posts
snowygrouch 19 posts
zumfab 14 posts
lars86 12 posts
Popular Days
May 23 2013
Aug 19 2014
Jun 6 2013
Jan 13 2015
snowygrouch 1
