Bed leveling routine tweak
billdempsey
Posted · Bed leveling routine tweak
Hey Daid,
Can you have the bed leveling wizard move the print head and bed to the proper starting position for the front left at the start of the wizard. Several times, I've tried the bed leveling wizard after an aborted print and the head/z-height just stays wherever it was when I aborted the print. Then, I have to guess the starting position where the head should be and manually move it there, in order to level it.
Thanks!
