Ok... I've spent a couple days experimenting now and there's something going on with Tinker on a specific 3d model I am trying to print. If I go back to the original (latest) UM2+ firmware it prints fine. I now tried slicing with cura 2.5, 4.1 and 4.7 and the results are similar- the print just stops after a while as if it were finished. The same model, sliced waaaaaaay back with an early cura (2.1 I think) still prints.
The weird thing is that I went back and redid the model with different topology, made it 100% error free, manifold and watertight but the result is the same. If IS a rather detailed model though, at around 50MB. Unfortunately, I can't share this particular model, since it's a confidential file, but I'll try a different model (that I CAN share) and see if I get errors on that too.
Tinker firmware - introduction
OK... more testing. Look at this:
I imported the gcode files into Simplify3d just to look at them. It looks like Cura has inserted random super-fast print head movements because the red lines are exactly where the print failed. UMs original firmware seems to be able to handle the files anyway, but Tinker stops printing when it reaches those lines every time.
Any thoughts as to what could be going on?
tinkergnome 862
3 hours ago, joatrash said:Any thoughts as to what could be going on?
Dunno, can you translate "random super-fast print head movements" into a more precise measuring unit?🙂
Or can you share the gcode file?
Haha, well looking at the screenshot... the red line seems to indicate a moment of 9000mm per minute!
But I did more digging. It looks like the problem might be hardware-related on my end. I suspect a faulty SD-card reader. (Or if it's not, then Windows is indexing the SD card even though it's not supposed to be.) Looks like errors start showing up in files when the SD card is removed. Information in the files goes missing, like here:
Broken copy on the left, error-free copy on the right.
Apologies for thinking it was a Tinker issue.
ONE puzzling thing though... the UM firmware seems to IGNORE the error and carry on, but Tinker stops. is there an extra-sensitive error-check in there?
- 2 weeks later...
The headbed of my UM2+ does not cool down anymore (temp keeps rising).
I think the mosfet for heater3 is broken and i'm not really in the mood of buying a new mainboard 😉
The mainboard has 3 heater terminals:
heater1 (occopied), heater2 (free) and heater3 (this is the heater for the headbed).
I also see that there are 3 seperate mosfets for all these 'heaters'.
So, i'm thinking, using the Tinker firmware, is it possible to use the 'heater2' terminal (not occopied) on the mainboard for the original headbed?
@tinkergnome Is there maybe a setting/option in the Tinker firmware to set heater2 as primary heatbed?
BR,
Ray
Edited by rayhollandtinkergnome 862
2 hours ago, rayholland said:So, i'm thinking, using the Tinker firmware, is it possible to use the 'heater2' terminal (not occopied) on the mainboard for the original headbed?
The buildplate heater draws a lot more current than a hotend. Dunno, but you should be absolute sure that the capability of the outputs is really the same before you change anything.
There are probably only minor things to change on the software side, but you have to compile a custom firmware in this case.
Would changing the line '#define HEATER_BED_PIN 4' to '#define HEATER_BED_PIN 3' in the pins.h be sufficient?
tinkergnome 862
10 hours ago, rayholland said:Would changing the line '#define HEATER_BED_PIN 4' to '#define HEATER_BED_PIN 3' in the pins.h be sufficient?
Probably yes. I would swap the pin numbers between HEATER_1_PIN and HEATER_BED_PIN
Take sure that you are in the correct section (MOTHERBOARD == 72) and it should work.
- 1 month later...
On 10/16/2020 at 3:25 PM, rayholland said:The headbed of my UM2+ does not cool down anymore (temp keeps rising).
BR,
Ray
I have same Issu but the heater dont work, so never start printing
Did you change the pin? because we can swtich to heater 2, but I dont know if the current would be supported because the mainboard has a finder relay 361190054011 that i dont know what is for...
So if you could do it, please tell us, I will do it too and tells you
Thanks!
How do you change the abort retraction? I've changed my hot end and it retracts way too much for the new hot end.
Edited by JRDM- 4 months later...
Hello guys. Are you using the latest stable version V17.10.1 or the newest one V19.03.1? Once in a while my UM2 inverts all axis by itself and I have to factory reset it. Does it happens to anyone?
My UM2 is one of the very first. I am using 17.10.1. The only issue I have is sometimes at the end of the print it will retract almost all the way back to the extruder motor. No other problems.
Top Posters In This Topic
35
14
11
9
Popular Days
Feb 7
6
Mar 4
6
Dec 22
5
Feb 12
5
tinkergnome 35 posts
gr5 14 posts
joatrash 11 posts
killerb77 9 posts
Popular Days
Feb 7 2018
Mar 4 2018
Dec 22 2017
Feb 12 2018
Popular Posts
tinkergnome
I was asked to sum up some facts about the alternative "tinker" firmware. Here are the basics and the main links to start with it: What is the "Tinker-Firmware"? It's an alternative firmware for
stephenbo
I would like to say thank you for your reply and helping me in my problem
gr5
I'd get a uninterruptable power supply. So you will need 2 of the features that come with tinkerMarlin. I mentioned above - you can set the Z position of the print head exactly. In this
Posted Images
Smithy 806
No, but I rarely print longer print jobs on my UM2+Ext.
I will give it a try in the next days, with a longer print job.
