Reduce Noise With Different Slicer
magicxman
Posted · Reduce Noise With Different Slicer
I noticed that when using different slicer to slice same parts, the printing 'music' or noise generated from the motor is different. Some slicers generated lesser noise. Does anyone encounter this? If so, let's poll which slicer generate least noise.
    The noise is a product of the accelerations in the printhead. You are undoubtedly getting different sounds due to the different approaches each slicer takes in reading how to generate the g-code. As the largest impact in the way it generates the g-code is going to be what the part physically is, it would be particularly difficult to quantify which is the most quiet.
    • 2 weeks later...
    If most of the noise is generated by acceleration of the printhead, NetFabb lets you manually set the maximum acceleration in the extended setup of the machine. Its default is 7 m/s2, so you can lower it and see if the noise goes down. Of course the build time will go up, depending on how many changes in direction and speed are needed.
    I have little experience with other slicers.
