ascii' codec can't encode character u'\xe4' in position 61:
hcb_kd
Posted · ascii' codec can't encode character u'\xe4' in position 61:
While trying to slice a file, Cura goes "something went wrong during slicing!", and on the last line of the report, it says:
UnicodeEncodeError: 'ascii' codec can't encode character u'\xe4' in position 61: ordinal not in range(128)
Does this make any sense to anyone?
I run Cura on a new W7 computer, and have just updated to Cura 12.12
The file was modelled in SolidWorks.
The entire report:
File C:XXXXX is being chain exported.
Carve procedure took 4 seconds.
Preface procedure took 1 second.
Inset procedure took 17 seconds.
Fill procedure took 39 seconds.
Speed procedure took 1 second.
Raft procedure took 17 seconds.
Skirt procedure took 1 second.
Comb procedure took 1 second.
Cool procedure took 2 seconds.
Dimension procedure took 1 second.
Traceback (most recent call last):
File "app_main.py", line 51, in run_toplevel
File "C:\Program Files (x86)\Cura_12.12A\pypy\lib-python\2.7\runpy.py", line 162, in _run_module_as_main
"__main__", fname, loader, pkg_name)
File "C:\Program Files (x86)\Cura_12.12A\pypy\lib-python\2.7\runpy.py", line 72, in _run_code
exec code in run_globals
File "C:\Program Files (x86)\Cura_12.12A\Cura\cura.py", line 78, in
main()
File "C:\Program Files (x86)\Cura_12.12A\Cura\cura.py", line 67, in main
sliceRun.runSlice(args)
File "Cura\util\sliceRun.py", line 89, in runSlice
skeinforge_craft.writeOutput(fileName)
File "Cura\cura_sf\skeinforge_application\skeinforge_utilities\skeinforge_craft.py", line 133, in writeOutput
return pluginModule.writeOutput(fileName, shouldAnalyze)
File "C:\Program Files (x86)\Cura_12.12A\Cura\cura_sf\skeinforge_application\skeinforge_plugins\craft_plugins\export.py", line 272, in writeOutput
gcodeText = skeinforge_craft.getChainTextFromProcedures(fileName, procedures[: -1], gcodeText)
File "C:\Program Files (x86)\Cura_12.12A\Cura\cura_sf\skeinforge_application\skeinforge_utilities\skeinforge_craft.py", line 42, in getChainTextFromProcedures
text = craftModule.getCraftedText(fileName, text)
File "C:\Program Files (x86)\Cura_12.12A\Cura\cura_sf\skeinforge_application\skeinforge_plugins\craft_plugins\alteration.py", line 94, in getCraftedText
return getCraftedTextFromText(archive.getTextIfEmpty(fileName, text), repository, fileName)
File "C:\Program Files (x86)\Cura_12.12A\Cura\cura_sf\skeinforge_application\skeinforge_plugins\craft_plugins\alteration.py", line 104, in getCraftedTextFromText
return AlterationSkein().getCraftedGcode(gcodeText, repository, fileName)
File "C:\Program Files (x86)\Cura_12.12A\Cura\cura_sf\skeinforge_application\skeinforge_plugins\craft_plugins\alteration.py", line 180, in getCraftedGcode
self.addFromUpperLowerFile(repository.nameOfStartFile.value) # Add a start file if it exists.
File "C:\Program Files (x86)\Cura_12.12A\Cura\cura_sf\skeinforge_application\skeinforge_plugins\craft_plugins\alteration.py", line 172, in addFromUpperLowerFile
self.distanceFeedRate.addLinesSetAbsoluteDistanceMode(alterationFileLines)
File "C:\Program Files (x86)\Cura_12.12A\Cura\cura_sf\fabmetheus_utilities\gcodec.py", line 356, in addLinesSetAbsoluteDistanceMode
self.addLine('()' + line)
File "C:\Program Files (x86)\Cura_12.12A\Cura\cura_sf\fabmetheus_utilities\gcodec.py", line 325, in addLine
self.output.write(line + '\n')
    I'm guessing you have a "non-standard" character in the filename. Daid's added the ability to recognize many of them but some things like accented letters and umlauts can cause issues.
        • 6 replies
