So I guess I'm not the only one running off the original UM2 firmware. I did update once everything went sideways. :angry:
Hi DeathMachine,
No, you are not alone for sure! I'm using the old firmware from 15.04.6 and this is the best match for an UM2 IMHO.. If I want a predictable print, I'm using Cura 15.04.6 period. I'm also using S3D, but mostly for monitoring the "gcode files" (the model) as this really give you a true picture of what to expect.
Sorry, but the new versions have to many issues, so I'll wait until all this is some stabilized.
Thanks.
Torgeir.
tinkergnome 927
Short answer: downgrade to an older version of the firmware, if you need this function.
Some more details are linked in this topic:
https://ultimaker.com/en/community/22423-changing-filement-halfway-print#reply-155614
