limburgmetaal 9 Posted November 28, 2016 in poor cohesion ABS i have printed with this reel of ABS before and worked fine, but for some reason there is a poor cohesion between the lines result a, brittle part that is not good Table 60° Extruder 220° Fan Off layer height 0.2mm speed 3600mm/min Nozzle 0.4 anybody any idear? Share this post Link to post Share on other sites
ultiarjan 1,076 Posted November 28, 2016 in poor cohesion ABS sure, you need more heat; try bed 90-100c extruder (depend on type of ABS) with 0.2 layers I guess minimal, 240c but probably even higher. enclose your printer; minimal the front, but better also the top; https://www.youmagine.com/designs/ultimaker2-top-cover-clips https://www.youmagine.com/designs/um2-minimalist-front-panel Share this post Link to post Share on other sites
limburgmetaal 9 Posted November 28, 2016 in poor cohesion ABS (edited) will thinnen layers be better or worse? Edited November 28, 2016 by Guest Share this post Link to post Share on other sites
