Yes I am always printing with brim, the problem is , even with the first brim catches it, it still high enough to get under the head and being dragged around...
- 2 weeks later...
Bumping this -- as this happens from time to time with my prints as well when the blob doesn't stick around the intended waste area.
I find the skirt helps with this sometimes...but sometimes, that blob appears near the nozzle and despite the best attempts to tweezer it off via pause....another one will appear!
Edited by GuestThis happens frequently w/ my UM3 also. I always manually remove the blob now. Sometimes, the blob will release from the extruder just fine, but then get stuck to the bottom of the fan case.
Hi Swissengineer,
We are aware of the 'blobs' not sticking to the build plate and we are working on a solution to the problem, thanks for reporting!
Sadly, I can't give an estimation on the fix date just yet. :( Keep an eye on the changelogs when new Cura's are released if the issue is fixed.
Regards,
Jeroen
Jeroen
2
- 4 months later...
Hi Guys,
Has this been fixed yet as i am having he same issue on nearly all prints running the latest firmware and software?
Thanks
Edited by Guest- 1 month later...
Hi Nigel,
I'm glad to announce it will be available when Cura 2.6_beta releases!
You'll have to be a little more patient, keep an eye out on our website!
Thanks for the heads up Jerooney. Look forward to this, Cheers
- 2 weeks later...
Hi Guys,
The bèta is online for a week now, has anyone tried the new function?
It's called 'Enable prime blob' and is placed in the 'build plate adhesion' category.
Regards,
Jeroen
1
SandervG 1,522
Hi Swissengineer,
thank you for your post. Sorry to hear that the little blob of filament makes it to your print. Do you print with a skirt? Usually this skirt also functions as a buffer to catch these kinds of things.
Looking forward hearing from you!
