How to Reduce Height Shrinkage?
eric-lester
Posted · How to Reduce Height Shrinkage?
I was wondering if someone could give some advice on how to decrease what I call "height shrinkage," that is, where the base of the print ends up being larger than the top of it. For example, I was printing a short ring with no buildplate adhesion out of PLA with a heated bed. The piece was about two inches across and a quarter of an inch high and is basically just a cylinder with letters across it. When I took it off the plate, I noticed that the top was clearly smaller around than the bottom! (In this case, only by about 1/16'' so it probably won't matter all that much.)
I looked the issue up and saw it called "elephant foot," but the reasons offered seemed weak. I can only guess that this occurs because the heated plate results in uneven cooling for the rest of the print. Regardless, any tips? Thanks!
    In my experience, there are two main causes:
    1) For good bed adhesion, the first layer needs to be squished hard agains the glass plate. This tends to spread that layer out a bit, thus widening it. Solution: calibrate the build plate for a higher gap between nozzle and first layer, so that the first layer isn't squished so hard.
    2) The heated build plate makes the bottom layers melt and sag a little bit, since the optimal build plate temp is around the glass transition temp of the material (= the temp at which it begins to get weak). Solution: use a lower build plate temp.
    Both solutions give a far worse adhesion of the model to the build plate. So I usually prefer a little bit of elephant feet, rather than bad adhesion, especially for difficult to print models.
