I apologize for the delayed response. We ended up installing Cura 2.3.0 instead of 2.3.1 and everything works properly. I do not know what caused the issue with 2.3.1. We have not yet tried to install 2.3.1 one another computer, but we will do so soon. I will reply on this thread with the conclusion.
We suspect a policy on your Windows installation may prevent "signed" applications from launching "unsigned" applications. The main Cura application is signed in 2.3.1, the CuraEngine is not. I believe work is underway to have both Cura and CuraEngine signed for 2.4, which would solve this (if it is indeed your problem with 2.3.1).
1
nallath 1,101
Could you post your log files?
Have you tried disabling your firewall? It tends to block the connection between the GUI and the slicing engine.
