Hi Patric M,
You'll have to turn it anticlockwise in order to tighten, made the same thing myself first time..
Try to add force directly helping feeding, if it helps add some more force. Adjust to mark two or around, will depend of the softness of you filament. Do you use PLA?
A little more info about the setup, nozzle size etc. will help here.
Good luck.
Thanks.
Torgeir.
It's a 0.4mm nozzle and sorry about the mislead, but I was actually turning it anticlockwise to try and tighten it, but it still wouldn't budge.
Torgeir 205
Hi Patric M,
Good luck.
Thanks.
Torgeir.
