CAN'T VIEW THE MODEL
Posted · CAN'T VIEW THE MODEL
Newbie so be gentle:)
Trying to import a model. I have both the .stl and .obj files! The .stl file loads but is not visible in any View Mode! The .obj file loads but is only visible in the "Layers" View Mode.
Once I attempt to re-size the model it disappears!
    Load in what version of Cura? Could you share the model & Log files??
    I loaded to Version 2.3.1 (Mac OSX operating system) Unfortunately I can not share the files due to a NDA (Non Disclosure). Is their any list of potential issues I could troubleshoot?
    Thanks
    You could try other objects. If these other objects work, there may be something wrong with your NDA'ed objects, but since you can not share them we can not see what might be wrong.
