The obvious answer is to not print a prime tower. You'd be amazed how far you can get without one!
Cura 2.4 has the option for a hollow prime tower, with more controlled wiping. It also comes with more temperature controls, which can further reduce oozing if printing without prime tower.
2
neotko 1,417
Increase avoid crossing distance. Or something alike.. Can't remember the name of the option. It will force for pva to take longer path and avoid going from a to b directly. Also while isn't always the best in terms of material used, increasing some options of the support generation like horizontal expansion and other that makes the supports interconnected will help the travel paths to stay away from the print part. Go to supports and unlock the many hidden options and read the help one bynone. There are many options that can help more or less to solve the problem.
For the tower falling down. I use yo increase the tower flow % (hidden option by default) to increase the volume of material deposited to get a stroger bond). Also you could move the tower (by changing manually the x/y position) so the tower 'fuses' with the PVA support, making it a much more robust tower.
I don't have photos here but will try to upload them tomorrow.
Oh also using Z hop (even 0.2mm) helps to have less force hitting your tower. But the main issue of the tower can be that it's a bit small and needs more material so all layers bond properly.
Edited by GuestLink to post
neotko 1,417
Btw pva doesn't work with ABS. It just doesn't stick one to the other.
