The silicone cover looked like that I think since I got the printer a month ago. (If not, it happened during the first print.)
I'm pretty sure it was because the print detached, but maybe it detached because it somehow got stuck to the nozzle? It's done the pushing the print around the plate thing a couple times, usually I've caught it pretty quickly. I thought I was fine to print overnight because I already ran two prints of the same model and it was ok. (Well, one had some warping, but no sliding around the build plate.)
I'll get in touch with my reseller, thanks.
SandervG 1,519
Hi Nullroute,
Thank you for your post. Sorry to hear you had some difficulties with your Ultimaker 3. Do you know if this happened because your print got detached from the build plate?
The silicone cover should normally protect your printhead internals. It looks like it is broken, can you confirm? Did this happen during cleaning, or was this already the case before you started a print.
About how to move forward, I would recommend to get in touch with your reseller. They should also have received instructions on how to help you get 3D printing again.
If you have any further questions, please feel free to ask!
