I don't think they are mislabeled, but maybe they should come with clearer instructions. I'll double check and see if and where they can be included. Thanks for notifying us!
- 2 months later...
For the reference. My current PID values on UM2 (Tinker firmware) before upgrading from 25W heater to 35W one:
P10.00 I2.50 D100.00
They can me be viewed using M503 command.
Maybe we should port the UM3 PID controller to the UM2? It has a few extra features that greatly assist in stability of the temperature control. Then we might be able to find a parameter set that works for both the 25W and 35W.
neotko 1,417
Well that certainly should be clear when you buy a 35W heater. Specially if inly says Ultimaker 2 Family.
Indeed your changes where perfect if the heater is 35W. Oficial firmware doesn't allow you to change pid of the heater, but @tinkergnome firmware does. Is much more flexible and it allows you to even change the esteps if you ever need it (along with some pretty useful options).
https://ultimaker.com/en/community/33482-tinker-firmware-introduction
Also @sandervg maybe the heaters are being mislabeled? Because it could be slightly problematic for novice users I think. Just my 2 cents.
Anyhow you fixed your issue perfectly @jofleck
jofleck 0
Perfect :)Then I´m not worried while printing
And thats the problem. The heaters aren't labeled as a 35W heater. In the moment I haven´t a use case for a more powerful heater. I don't care about waiting a few seconds longer for heating up. I just wanted a replacement which works out of the box and I think many other users too
