I would advice you to go by all the pulleys with your screwdriver and double check them.
Don't forget the one at your motors.
This would explain your first and third problem. Due to a loose pulley the axis can rotate freely in the pulley, and the movement can not fully be transmitted to the print head.
Regarding to problem 2, your bed is most likely just a little bit too low.
Please go to wiki.ultimaker.com/Calibrate for an image on how your first layer should look like.
The filament should slightly be pressed in the tape for good adhesion.
But keep in mind not to block the hole in the nozzle because then no filament can be extruded.
On that page are also tips on how to level your bed again.
Good luck!
SandervG 1,519
Hi Joe,
This sounds like a typical loose pulley problem.
Good luck!
