ColorFab XT Retraction
BrayChristopher
Posted (edited) · ColorFab XT Retraction
I am trying to print a bed full of small parts (50ish).
Normally I avoid the stringing issue with XT by just printing one part at a time. But I need to make about 3,000 of these parts...... so it would be nice to print a whole bed's worth over night.
Has any body else run into a similar challenge?
I use Simplified 3D as my slicer.
Currently my setting are:
Retraction Distance: 4mm
Extra Retraction Start: 0mm
Retraction Vertical Lift: 0mm
Retraction Speed: 1500 mm/min
Coasting Distance: 2.5mm
Wipe Distance: 3.0mm
Layer Height: 0.15mm
Top Layers: 3
Bottom Layers: 3
Shells: 2
Out Line Direction: Print Outside-In
Print island sequential with out optimization: On
Use Random Start Points for All Perimeters: On
(I was hoping this would spread the pimples out so that they don't build on one another)
No Supports
Extruder Temp: 240c
Bed Temp: 70c
Fans turn on at layer 8
Fan speed: 50%
Default Printing Speed: 3000 mm/min
Outline Underspeed: 65%
Solid Infill Underspeed 70%
X/Y Axis Movement Speed: 3000mm/min
Only Retract when crossing open spaces: Off
Force Retraction between layers: Off
Minimum travel for retraction: 0.02mm
Perform Retraction during wipe movement: On
Only wipe extruder for outer most perimeters: Off
I think those are all of the settings that matter.....
Please and thanks.
Posted · ColorFab XT Retraction
New settings! The part looks very good. At least for what I need it for anyway.
Retraction Distance: 5mm
Retraction Vertical Lift: 1mm
Retraction Speed: 1600 mm/min
Coasting Distance: 1.0mm
Wipe Distance: 2.0mm
Top Layers: 3
Bottom Layers: 3
Shells: 2
Out Line Direction: Print Inside-Out
No Supports
Extruder Temp: 240c
Bed Temp: 70c
Fan speed: 50%
X/Y Axis Movement Speed: 6000mm/min
Force Retraction between layers: On
I have only tried a small batch of these (16 at a time). Soon I will try a larger batch.
    For more reliable/consistent prints, I'd recommend leaving retraction enabled, but setting retraction distance to 0.0mm and making sure your movement settings are as fast as they can be.  As well as lubricating your rods.
    I think a z-hop of 1mm when retracting will be fine.  I print without fans, and I had better results going shorter - around 0.25mm.
    • 3 weeks later...
    I found that when printing a larger set of these, I would get really fine strings between the parts.
    So I played with the settings some more.
    Retraction Vertical Lift: 0.5mm
    Retraction Speed: 2000 mm/min
    Coasting Distance: 2.0mm
    Wipe Distance: 6.0mm
    Top Layers: 3
    Bottom Layers: 3
    Shells: 2
    No Supports
    Extruder Temp: 237c
    Bed Temp: 70c
    Fan speed: 50%
    Only Retract when crossing open spaces: On
    Perform Retraction during wipe movement: Off
    Here are the results:
