foehnsturm 969
Using an Olsson block and a Matchless block for dual extrusion on an UM2+. Nozzle change is 20 sec and I can immediately continue printing, no X/Y/Z re-calibration needed.
Using E3D's V6 on a corexy printer. Nozzle change takes 2 min and requires additional pliers to hold the block. I've to re-calibrate X/Y/Z because the nozzle tip which is far apart from the mounting bracket will most likely have moved a few fractions of a millimeter.
meduza 191
Actually, the Olsson Block that is standard on the UM2+ and available as a upgrade for the UM2 is way easier to change nozzles on, and it can use any E3D Nozzle.
ultiarjan 1,220
WOW this reads like a E3D commercial .....
My short reaction, as before...
Unless you need real high temperatures the ED3V6 is a downgrade compared to the Olson block, as changing nozzles is a (IMHO) real pain in the @$$ compared to the Olson. Also the V6 (the 3mm bowden version) is not nice with PLA. If you want to try it... I still have a V6 laying around, you can have it for free if you want to try... I don't use it anymore (I used it dedicated for ABS, but I now have the UM3 for that)
Replacing the feeder is a good idea if you still have the old black feeder on the UM2. The titan can be a good option, I never tried it, the UM2 plus feeder is a good option (you can buy it separately if you ask any UM reseller) And ofc there's the bondtech, so plenty options for good feeders.
Edited by GuestLink to post
