Where are the Expert Settings?
KetoCura
Posted (edited) · Where are the Expert Settings?
Hello everyone, I have had an issue with two models by now, and I'm almost certain that the Fix Horrible setting in the Expert Settings would be able to fix it.  However, after scouring the internet, repeatedly pressing Ctrl + E in hopes that it would work, and searching every square inch of Cura, I have yet to find the Expert Settings.  Don't get me wrong, Cura is awesome; I just need to find these (obnoxiously hidden) settings.  Thank you!
    Posted · Where are the Expert Settings?
    I assume you're talking about Cura 2.X
    Those settings are now under "Mesh Fixes" after you've switched over to the "Custom" mode. You might have to add the settings in via Preferences -> Configure Cura, click on Settings and then put a check box on all the settings you want visible.
