problems with loading of the profile after installing of cura 2.4.0 beta
Ultimak3r
Posted · problems with loading of the profile after installing of cura 2.4.0 beta
I wanted to try the cura 2.4.0 beta version, after I installed the version I realized that some of the values in the custom profile are not changeable anymore or they have the value NNA..... something. So I decided to go back to 2.3.1 and now i can't change the profile at all anymore. A new installation of cura could't slove the problem. In the moment I let the cura program run on a second PC and there the 2.3.1 works correctly again. What registry entries, files and folders I have to delete that I can install the 2.3.1 Version on my PC, like the programm was never installed on that maschine.
Thanks alot for your help in advance.
best regards
Ultimak3r
    Deinstalling of cura 2.3.1, manual deleting of the folder C:\Users\xxxxx\AppData\Local\cura and installing of CURA 2.3.1 solved the problem.
    I guess there should be a popup during the deinstall if you want delete everything or if you want to keep your settings.
