DidierKlein 730
That's a pretty cool a idea to make a lightweight direct drive, i'm guessing that the extra weight is not that much and has no impact on vibrations when printing faster.
Are you planning to make it available somewhere ? The gears are metal or printed? Are you using the same motor as the original feeder?
Awesome work anyway!
HiThat's a pretty cool a idea to make a lightweight direct drive, i'm guessing that the extra weight is not that much and has no impact on vibrations when printing faster.
Feedhead weight now 49grms .I removed the material cooling fans scrouding ect a year ago and replaced with air from a pump witch fans out just below the hot end nozzle .The only fan i use is to cool my hotend setup whitch is not standard
so should be a lot lighter than the original. Bevel gears are brass motor is the
original ultimaker material feed motor.As to making feeder a kit all depends on the
cost and feedback i get back.Now working on idears fo MK 2.
Thanks all for your interest.
Rod.
The bowden fan is an interesting idea.
https://ultimaker.com/en/community/3435-new-fan-cooling-design#reply-19327
https://ultimaker.com/en/community/3435-new-fan-cooling-design#reply-19299
Looks like you picked the right username for this drive feature
1
Hi Thanks.Looks like you picked the right username for this drive feature
Hi replacing the fans with an airjet has worked out well for me as it gives
me more control of temp when printing.Fans can produce to mutch air to the wrong place that can have an adverse efect on buildplate temp and nozzle temp
resulting in bad prints and other problems plus they add extra weight to the moving printhead. I printed a Tourbillon watch by Christoph Laimer with the airjet with very few problems.
- 2 weeks later...
rod 3
Hi print quality is very good. more consistant than with the bowden tube feeder.
Rod
[/media][/media][/media][/media][/media]
