- 2 weeks later...
DidierKlein 730
Damn i missed this post! Very cool stuff gudo, big fan. Fun to see that the same idea popped twice on the forum lately but with different orientations
So i beleive that the square rod is connected to the knurled wheel (or to a gear), when the head is moving i guess that the knurled wheel has some movement too, could it increase the grinding of the filament or not?
Would be really interested in that mod for one of my printer!
Edited by GuestDamn i missed this post! Very cool stuff gudo, big fan. Fun to see that the same idea popped twice on the forum lately but with different orientations
Hi Didier !
Thanks, yes the direct extruder pivots freely on the print head for following the X/Y motion,
it turns around 60° yaw angle from the extrem left front corner to the extrem right back corner, the axis of this yaw rotation is in the axis of the filament, there is absolutly no impact on the knurled wheel rotation feeding, since now closed to 200 hours print works I have no any grinding issue or something else with the Bondtech wheels used, also no any backlash or friction problems on the direct feeder system.
I start soon to do tests with stock UM feeder components, stepper motor and knurled wheel, I will see if I will get the same result !?
Yeah ! it will possible to add it to one of your printer, it's a real" add on" plug and play, this will not require any modifications (hardware/software) on your printer,
With an another stepper motor, eventually we can leave everything in place just remove the bowden tube and add the direct system on the top of the machine.
1
I wrong a bit! just to shorter the 4 stock UM screw heads of the UM2 print head !
DidierKlein 730
Oh yes indeed for the rotation of the feeder
So you use bondtech knurled wheel, is it like in the bondtech extruder? (two knurled wheel with a gear somehow?)
I use the standard Bondtech 2 gears feeder, the feeder has a 1/4 turn spring unloader key to release the spring pressure of the driven gear for change the filament by doing if it need a direct atomic nozzle cleaning in the same process.
an alternative version inspired by IRoberti /Fat IRoberti Neotko solution
3
How do you 'connect' the output of the extruder to input of the hot end? A piece of Bowden tube?
Just thinking on how It could be modified for an UMO head...
Hi Amedee,
With a piece of a standard PTFE tube, not UM Bowden tube
Neotko will soon test the system with 1.75mm mod on his UMO, the above Fat IRoberti feeder photo shows his future direct feeder.
1
Hi Amedee,
Yay!!!
Also afaik making an adapter to a UMO head would be just a matter of changing the x4 points where it screws (I think).
Woohoo can't wait to print some filaflex on day1!
Hi Amedee,
Yay!!!
Hi Neotko ! you think right !
Yes indeed, just the "bottom" plate would differ.
I was also thinking this plate could be a bit higher -- e.g. On my E3D head I need some clearance for the thermocouple amp. Obviously the height of the motor would need to be adapted to keep the axis perfectly level.
Time to order BondTech gears...
- 2 weeks later...
Assembly was quite easy. Basic esteps test to follow and flexibles on sunday.
1
First test I was gonna finish the estep calibration but choose to insert Flexible 86A shore from smartmaterials
So.. printing flexibles with PLA settings (mind the temp change ofc)
Amazing, right now I'm already around 1k retractions in 21minutes and no error, good looking infill... amazing @gudo
Please check this!! I'm drooling!! OMG!
And this is the first print with flexible!! Niahahahahaah!!!
It indeed works, and works superb!
4
Very interesting stuff.
a) There's a visible reduction on ringing. Anders theory about part of the ringing coming from bowden/feeder/pressure seems likely.
b) There's a huuge reduction on blobs and z mark at highspeeds, clearly the zero backlash from the filament being on a bowden tube helps to avoid suden changes on pressure.
c) I just did some Recreus filaflex, 3k retraction test printing one of my keychains changing only the retraction distance to 1.2mm and it does work. But it does drip much more than smartfil. It will need some coasting adjustments to make fine details but small txt prints almost ok (mind the dripping). I was able to lower the print for the half of the print to 230C without underextrusion or problems.
Soo... WOW!
1
Hi all !
Thanks a lot Neotko ! It's highly gratifying to know that it can work just as well after a design job
1
Another day, another test. This time trying to get rid of any dripping from flexible filament. So far, so good.
Printing flexibles with this is almost like PLA.
1
This is self explanatory
4
3dcase 37
brilliant cool stuff +1
