My bad. I saw the project file and missed the font itself. Got it now, thanks. Is it missing a space character (ASCII 32)?
11 hours ago, RayW said:When you print 2mm tall text, what's the width of the stroke and the line with? How are you printing narrow lines like that with a .4mm nozzle? Are there other slicer adjustments required (speed, retractions, feed rate)?
As mentionned in the wiki page I've designed this Font to be print with the 5.0 release of Cura . 2 mm is the minimum for a 0.4 nozzle and in this case the width is equal to 0.4 or closed to 0.4, and you will have just one wall. But I don't recommend this size, with this nozzle size. It can be used just to indicate something but you will not get a clean text.
4mm (0.8 width) is a prefered choice in this case.
Edited by Cuq
Forgot to say earlier: the height of the text (= how much it is raised or recessed from the surface) is also important for legibility and quality: too thin and it will not be legible, too thick and it will get more deformed. You might also want to play with that. Usually, I make it raised 0.2 to 0.3mm, or recessed 0.5mm. Hollow watermarks look best around 1mm thick, sitting 0.5mm below the surface. When buried too deep, watermarks will be blurred and unreadable.
Watermarks can be (1) hollow text, or (2) solid text surrounded by a hollow rectangle: both give a very different appearance, with the solid text in a hollow rectangle usually looking better. Both versions are shown in my testplates.
Small recessed text is most problematic: the nozzle can not get into thin openings of characters like N, M, W,..., so these voids tend to get closed.
See my test-plates with different heights of raised and recessed text, and different watermarks (via URL above). You can simply print these STL-testplates, and see how it comes out. Each STL-file is accompanied by a JPG showing what it should look like.
Further, the reason for printing slow is that this gives less ringing and less overshoots, less thickening of corners due to braking, and less variations in nozzle-pressure, and thus less variations in extrusion-rate, and thus smoother letters with less defects. The reason for printing cool is that this gives less stringing, and a more accurate shape, as long as you have no underextrusion. Thin layers also give a more accurate shape, where in thicker layers the text looks rather like bent sausages.
The bright yellow plate has solid watermark text surrounded by a hollow rectangle, caps height 3.5mm.
- 1
- 9 months later...
Also trying out printing text. The top one was done with a 0.4mm nozzle, the bottom at 0.25mm. The best standard font I have found is Roboto Bold, though for what I am doing I only need Upper Case letters, so haven't tried Lower Case.
It doesn't seem to be a standard part of Windows but I found it in OpenSuse Linux. I printed both very slowly, as you can see I had some problems with blobbiness here and there. I printed with a 0.5mm depth and very slowly and with a 0.1mm layer height, I am going to try 0.3mm and maybe 0.2mm depth and see if it helps reduce/eliminate the blobbiness.
- 3 months later...
On 1/8/2017 at 2:01 PM, gr5 said:
I can't believe how good this looks. I've seen some descriptions of how to do this, and most z-hop over the red print when printing the first layer of white. You appear to be printing the first layer of white without regard to the red that's already been laid down. Doesn't that severely squish the white filament as it's printed over the top of the red? I assume the red cannot be more than 1 layer high or the nozzle would trip over the red print when printing the white. It's sure a lot easier than worrying about aligning the text with a cavity in the cube.
GregValiant 1,245
If you allow the first layer of the letters to be the base color, and then switch colors for the second layer, then the nozzle is above the base for travels between the letters. It makes post-process cleanup of any strings much easier as the lettering color won't stick near as well to the base color.
It has been a while since I did these letters. I think I did either 0.1, 0.15, or 0.2mm layer height (and only a single layer) for the red "part" and then as a completely separate part I did the white part which indeed was identical and flat and ignored what letter(s) were being printed in red before hand. The white part was almost certainly 0.3mm thick on the bottom layer.
One advantage of having it as 2 separate prints is you can use a razor to cut away any strings/traces or even decide to clean the bed and start over. Also it's important to use a dark(ish) color. Red worked great. Black will work great but yellow probably wouldn't work well. Also the part itself needs to be white - otherwise some of the color will show through.
Top Posters In This Topic
9
7
7
5
Popular Days
Jan 9
11
Sep 13
5
Jan 8
4
Jan 10
4
geert_2 9 posts
rich17222 7 posts
RayW 7 posts
neotko 5 posts
Popular Days
Jan 9 2017
Sep 13 2022
Jan 8 2017
Jan 10 2017
Popular Posts
geert_2
In the beginning, I also had trouble that Cura wouldn't print things smaller than 0.4mm (UM2 with standard 0.4mm nozzle). So for printing small text, I designed my own character set on a 0.5mm grid. T
geert_2
I didn't make a real font-file, since I don't know how to do that. So to set text, you need to copy and pasted each character from the character set, letter by letter. Like in the old days
krys
Hi there, Long post ahead. Sorry. Hope it helps. I have on several occasions, and just recently too, done some letter printing. Here are some observations of your situation based on my experienc
Posted Images
Cuq 198
The ttf file is available under the indicate link, as well as the project file if you want to modify the font
