Did you change the bed temp manually? I ask because I found a bug to make that and is adjusting the core temp +X amount while the bed heats. That creates a bug (that I forgot to write anywhere @daid)
So. If you launch a print after a print. The cores MUST (silly imo) cool to 50C before they heat again (waste of time that must be for some security reason?). So, if while the bed heats you change one or other core to +X amount of temp, then the core never reaches the 50C that the firmware wants to start heating the cores.
Did I explain myself?
Basically, don't set an temp+ until the cores start heating, or you will be on the heating cores stage at infinitum).
This very well could be the problem as i did just adjust temperatures on the system yesterday. The restart fixed things for now but I'll keep an eye on it after I change bed temp again. Thanks!
neotko 1,417
