From Windows command line:
set PYTHONPATH=%PYTHONPATH%;C:\My_python_lib
To set the PYTHONPATH permanently, add the line to your autoexec.bat
. Alternatively, if you edit the system variable through the System Properties, it will also be changed permanently.
zaqi 1
Hi @Harry Plotter,
I can figure it out! thank you so much for your help! will upload the video soon
Best,
Zaqi
Smithy 1,132
It an older topic, but in case someone don't want to use Python 3, it is really easy to "port" it to Python 2. There are only 4 lines to change and it runs well with Python 2.x.
Here is a diff of the changes:
7,8c7
Edited by Smithy< from six.moves import urllib
> from urllib.request import urlopen
76c75
< response = urllib.request.urlopen(imgurl)
> response = urlopen(imgurl)
78c77
< f = open(filename,'wb')
> f = open(filename,'bw')
81c80
< print("Print progress: %s Image: %05i\r" % (progress(), count))
> print("Print progress: %s Image: %05i" % (progress(), count), end='\r')
Typo
