Extrusion Upgrade — reattaching the threaded standoffs to the PCB?
dwardio
Posted · Extrusion Upgrade — reattaching the threaded standoffs to the PCB?
Installing the Extrusion Upgrade on my UM2 this morning. Everything went well until I removed the four screws holding the PCB in place. I supported in in place until the four screws were removed, but when I gently pulled it away, the four black plastic spacer fell away (expected) as did the four threaded metal standoffs that were attached to the PCB itself (definitely not expected). Continued the installation, but now I am stuck since the threaded standoff are no longer attached to the PCB.
With soldering being the last resort, any ideas how to safely reattach the threaded standoffs to the PCB? Epoxy, J-B Weld, ???
Guess I could replace the screws with longer ones and fasten them (through the now-empty standoff holes) from the back with nylon nuts.
Any ideas, suggestions?
Thanks!
    Ended up going with J-B Weld (Steel Epoxy), making sure not to short any traces. Rock solid connection and was able to finish my extruder upgrade w/o further issues.
    Problem solved.
        • 6 replies
