I'm trying to systematically work through all the issues that could be causing the underextrusion and the bowden tube is also on the list... However, I've definitely hit at least 50 hours of printing.
When I disassemble the hotend, will the isolator coupler look burnt and deformed if its ready to be replaced?
What is the difference between TFM coupler and PTFE? Which do you recommend I purchase?
How can I visually tell if the bowden tube needs to be replaced?
neotko 1,418
Indeed it is. 50-200 print hours should be enough to wear it down, deforming it or just burning it down due heat.
TFM is the plastic used on the um2+ and is available for UMO on 3dsolex resellers, it should give you much print hours. Ofc the standard PTFE glass filled coupler is sold by any UM reseller.
If you remove it inspect it you should be able to see if is done for good or is the bowden moving out from the clip, feeder needing a metal brush cleaning or other possible issue.
