SD Card Stuck in Ultimaker
Foxi-5
Posted · SD Card Stuck in Ultimaker
Hi all,
I've been printing happily for a long time now. No real dramas until today. The SD Card is stuck in the Ultimaker. Pushing on it will no longer release it.
Does anyone know if there is a simple way to fix the unit? I've got some pliers handy for when the last print finishes in a few hours, to pull out the card.
I'm a bit reluctant to stick sharp stabby things into the socket in case I rip something apart....
Alas, the machine has been wonderful till a few minutes back.
Many thanks for your responses. :)
    Hi All,
    Thanks for your replies, after a bit of looking and fossiking, I've found some shaved plastic that came from the SD Card. Somehow managing to push something askew. Removed the plastic and it's all good now.
