PidTune Ultimaker 2 with e3d v6
Alil2096
Posted · PidTune Ultimaker 2 with e3d v6
Hi all, i'm installed an e3d v6 on my UM2.
Now i must to do the PidTune, because the heater cartridge is to 40W. But i've so much problem;
If I connect the printer to my macbook with pronterface, I send the M303 command after a few second pronterface say me:
 >>> M303SENDING:M303PID Autotune startPID Autotune failed! Temperature too high
What can I do?
Tkanks a lot ;)
    Are you doing this with warm hot-end?
    Marlin gives this message when you overshoot the target temperature by 20°C. Since you don't specify a target temp it is 150°C by default so if you start with a hot-end warmer than 170°C it will abort.
    Anyway, you should do PID tuning at the temperature you usually use -- if you typically print at 215°C, use:
    M303 S215
    Set manually temp to 200C and wait for your hotend to calm down. Then execute a PID to 210C. Since is 10C near, it shouldn't go 50C+ target and should guve you a decent PID value.
    That is very weird, there is no way you can gain 40°C in 1 second...
    I would suspect something wrong with the sensor, or the cartridge generating interference...
    Is this the 'official' E3D upgrade kit for UM2?
    Btw I had a heater from UM that was crazy and they replaced it for me.
    https://ultimaker.com/en/community/18625-solved-um2-pid-autotune-failed#reply-152021 Also interesting PID post
    @amedee
    No, there is only original e3d :)
    Probablty i have found the problem: the heter cartridge is 12V, but UM work with 24V..
    Right?
    Oh indeed. Not good to overdrive a heater with double its power. Also slightly dangerous.
    Yes, I so.. I'm very stupid..
    I've just bought the new cartridge (i've some 3d printer, but all works with 12V).. Thaks a lot!
    Posted (edited) · PidTune Ultimaker 2 with e3d v6
    Yes that's why I was asking if you bought the E3D UM2 upgrade kit as opposed to buying just the hot end, as in the first case they would have sent 24v automatically...
    Happy you found the issue.
